There is another small problem in version 1.7.1 is no longer possible to see the new device in the tree and it is therefore not possible to place them on the map.
does not show the device in tree
Think you can solve it,
Thank you always for your help.
Home Automation - Roller Shutter
Re: Home Automation - Roller Shutter
we will remove that tree and the map from the Blue UI anyway. It is a technical UI and we are rewriting it.
I'm sorry, it was very convenient to place the device on the map,
You can not rename the device FGRM - 222 last installed, it happens to you?
I upgraded to the latest official version 1.7.1 released and roller shutter are back to not allow any more settings here's an example.
What can I do to fix this? Thanks to all those who want to help
http://s29.postimg.org/iq8zpo3jr/Scherm ... _13_08.png
I believe you have solved now. Just repeating the procedure.
@PoltoS,
could you include the changes needed to have the Roller Shutter Fibaro 222 integrated in the system so that at the next update everything will work?
@PoltoS,
Yes, I repeated the procedure you had indicated that you and eric Orae and back to work,
tank's
tank's
Polto's I'm sorry if I renew my request, but if you can not delete the map function in UI Expert, I think it's really nice is very helpful.
So if you can not remove, thanks and ever thanks for the splendid public work that you gave us.
Sorry for my english use google translator
http://s15.postimg.org/dp58i4fgb/Scherm ... _47_59.png
http://s23.postimg.org/3o9g1aagb/Scherm ... _40_07.png
I agree with dolam that a map view is nice for large setups. But probably it should be re-implemented in the new interface in some way. Now that the old interface is becoming the expert UI it doesn't really belong there anymore.
@dolam:
We are thinking to "re-invent" it in the new UI in future, since the old Blue UI is based on Z-Wave directly and not on abstract concepts introduced in automation engine.
But keep calm, the old Blue UI will be kept for a year at least.
