No valid UUID set
dukerider33
Re: No valid UUID set
Post by dukerider33 »
lanbrown wrote:
30 Jan 2023 18:33
dukerider33 wrote:
30 Jan 2023 11:22
lanbrown wrote:
30 Jan 2023 00:25
Home Assistant supports Z-Wave. If you have a single device, then maybe just getting a Z-Wave USB adapter and using the Z-Wave integration in Home Assistant will get you what you need.
https://www.home-assistant.io/integrations/zwave_js/
Which USB adapter would you recommend? I am runnnig HA on Proxmox as virtual machine, so I am not sure how to map an UDB device through Proxmox to virtual HA
Since we're just talking about one device and if you wanted the ability to run Z-Way in the future. Z-Wave.me has the UZB:
https://z-wave.me/products/uzb/
I will give the Z-Wave.me UZB adapter a try, looks like this will be the easiest solution for my needs.
Thanks a lot! Once I have it I will report back here and let you know the outcome.
dukerider33
Now I have bought a Z-Wave Aeotec Z-Wave 7 Stick, connected that one to my HA in Proxmox and everything is fine in HA.
Thanks for Support, I will send back the Rehau device since they have told me they don't provide a newer Z-Wave version.
LasPro
Post by LasPro »
My Z-Wave integration into HomeAssitant worked quite well. But after replacing thge router I had to reconfigure the connection.
Result: "No valid UUID set".
According to this thread that issue should have been solved for a long time already. What went wrong and how to fix it?
lanbrown
Post by lanbrown »
LasPro wrote:
12 Dec 2024 21:10
Did you try this from the first page?
https://forum.z-wave.me/viewtopic.php?p=93547#p93547
MyZip
Post by MyZip »
lanbrown wrote:
12 Dec 2024 22:24
LasPro wrote:
12 Dec 2024 21:10
That did not work for me. I am still getting the error No valid UUID set.
Using Administrator or the new created user does not make a different.
When calling http://192.168.178.123:8083/ZAutomation ... rst-access I get a valid looking result:
{"data":{"firstaccess":false,"uuid":"81113115-a718-acfd-f901-8f442c0a9cfc","serial":"81113115-a718-acfd-f901-8f442c0a9cfc","mac":"dc:a6:32:3e:ab:a0","remote_id":192529,"ip_address":""},"code":200,"message":"200 OK","error":null}
Software info
Firmware version v4.1.4
UI version v1.16.1
Built date 22-07-2024 01:37:26
Capabilities: SlM
@PoltoS: Which logs should I share? https://community.home-assistant.io/t/p ... y/399882/2
z-way-server.log does not generate a log when calling from home assistant (but does generate logs in general e.g.)
[2024-12-21 17:04:13.879] [zway] Adding job: Get background noise level
[2024-12-21 17:04:13.881] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2024-12-21 17:04:13.883] [D] [zway] RECEIVED ACK
[2024-12-21 17:04:13.883] [D] [zway] RECEIVED: ( 01 05 01 3B B5 B0 C5 )
[2024-12-21 17:04:13.883] [D] [zway] SENT ACK
[2024-12-21 17:04:13.883] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 181 (0x000000b5)
[2024-12-21 17:04:13.883] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 176 (0x000000b0)
[2024-12-21 17:04:13.883] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 127 (0x0000007f)
[2024-12-21 17:04:13.883] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -75 dBm, Ch#2: -80 dBm, Ch#3: not available
[2024-12-21 17:04:13.883] [D] [zway] Job 0x3b (Get background noise level): success
[2024-12-21 17:04:13.883] [zway] Removing job: Get background noise level
Looks like Z-Way is working correctly, but the token is not entered. Please doublecheck the token - it should start with a / symbol.
Please check this article: https://help.z-wave.me/en/knowledge_bas ... tegory/88/
