Fibaro FGS221 dual relay
All config options not listed
All config options not listed in ZDDX can be accessed from Expert commands using Configurtion Set command. Refer to the manual to get proper parameter id
Thanks. Yes I had found that Configuration Set command the second time I looked. The first round I apparantly was overwhelmed by the three Basic commands and the PowerLevel command, which I had never seen before.
Powerlevel can be set between -9dbm and -1dbm, and 'normal'. Mine is set to -9dbm. I suspect this has to do with signal strength, but I have no idea what this means in relation to other devices where I don't have the option to change this setting.
Don't take in mind. It is
Don't take in mind. It is only about testing signal strengh and not to change power of daily transmission.
Thanks for the information
Thanks for the information. It confirms what I thought
