New Danfoss Thermostat
Interpunktor
Post by Interpunktor »
Due to the evolution of my z-wave infrastructure my second device arrived yesterday. It is a probably "new" Danfoss Thermostat witch has a own Ordernumber: 014G0012 Package announce it content with "Danfoss living connect z"The old, quit messy and -LivingConnect only-, Thermostat might be ordered with Number 014G0002.The z-wave command classes described in the manual are:Z-Wave Command ClassCOMMAND_CLASS_BATTERYCOMMAND_CLASS_CLIMATE_CONTROL_SCHEDULECOMMAND_CLASS_CLOCKCOMMAND_CLASS_VERSIONCOMMAND_CLASS_MANUFACTURER_SPECIFICCOMMAND_CLASS_MULTI_COMMANDCOMMAND_CLASS_PROTECTIONCOMMAND_CLASS_THERMOSTAT_SETPOINTCOMMAND_CLASS_WAKE_UPNevertheless this device shows only up in the Device Control->Status SectionI'm not able to control it via the GUI.Sending commands like---://My.raspi.local:PORT/ZWaveAPI/Run/devices[3].instances[0].commandClasses[67].Set(1,21)for setting its Temperature to 21 degree or---://My.raspi.local:PORT/ZWaveAPI/Run/devices[3].ThermostatSetPoint.data[1].val.valuefor getting the setting are successful but i would prefer to do that with the GUI.Would someone please help me and give me a hint where to change the NIF or somewhat else which will probably  allow me to see and set the Temperature in the Raspi Z-Way GUI.Or should i go back to the z-cloud (which doesn't support my first device, the AEON LABS Multisensor for now)Thanks in advanceKlaus
This problem was fixed in our
This problem was fixed in our UI. The new version will be released on May 5th.
