Fibaro door-sensor FGK-10x
hako74
Post by hako74 »
I cann't find the Fibaro door-sensor FGK-10x in the device list of Z-Cloud. The device is mentioned here: http://www.pepper1.net/zwavedb/device/367 So I thought it would be available.
This is a set of different
This is a set of different coours of Fibaro Door Sensor (they have same f/w, so one single description in the database)
hako74
I understand the Fibaro door
Post by hako74 »
I understand the Fibaro door-sensor is basicly one device, but in different colors so different product-ids.
But the problem is, the Fibaro door-sensor is not in the select list on Z-Cloud. The first suggestion from Z-Cloud is the Vision door-sensor, but the Fibaro door-sensor is just not in the list.
Ah, indeed! We need to update
Ah, indeed! We need to update the base in Z-Cloud.
You cn also do it using a special predefined scene.
hako74
Still not available, how can
Post by hako74 »
Still not available, how can I do it using a scene?
Remember, I'm using Z-Cloud, not z-way with a razberry
Frédéric
HI,
Post by Frédéric »
HI,
Did you mean "os.system("cd ZDDX; ./UpdateXMLs.sh")". It seems not updating.
Can you help us?
evansj
Post by evansj »
"You cn also do it using a special predefined scene." - please can you explain? Thanks. :)
michap
Can somebody add the device and update the base in Z-Cloud?
Post by michap »
Would be nice to have same database "everywhere" ... I think it could be possible to create a sync script, right? ;)
We have launched update.
We have launched update. Shuld be done in several hours (we are updateing it for all clients).
