Troubleshooting
tyrrellsystems
Troubleshooting
Post by tyrrellsystems »
I currently purchased a USB-dongle with some sensors.
A couple of days ago I installed and it worked fine. But now, while trying to initialize the Z-Connector on another PC there is a message that pops up:
The application failed to initialize properly (0xc0000135). Click on Ok to terminate the application.
Do you have any solution for this kind of problem?
.NET is missing on your PC
Your PC probably Windows XP or Windows 2000 with no software installed at all.
Z-Connector requires Microsoft .NET version 2.0 or greater to be installed.
You can install the minimal .NET 2.0 (if your PC is 64bit, choose x64 package), but we suggest to install latest .NET 4 framework.
tyrrellsystems
Solved
Thanks, updated all .NET Framework versions with all service packs and now it works fine.
