Time zone change
catman
Time zone change
Post by catman »
Good morning
This morning the UK moved to British Summer Time (UTC+1)
I see the Cloud is still working on UTC.
Will this / can this be changed or do all of our scheduled events need altering?
TIA
C
Z-Cloud automatically switched to summer time too
May be you have to reconnect to Z-Cloud to see changes.
catman
Did it?
Post by catman »
Because this is what I see this morning: 0547 BST:
2012-03-26 04:47:01,847 Rules.INFO Event: from 3:2 to 1:1, Report, value: [37, 0]
2012-03-26 04:47:01,796 Z-Wave.WARNING CAN found while no job awaiting ACK...
2012-03-26 04:47:01,755 Z-Wave.INFO Send to device 3, instance 0, Multi Channel Encapsulation V2: Send to device 3, instance 2, switch binary get: Delivered
2012-03-26 04:47:01,632 Z-Wave.WARNING CAN found while no job awaiting ACK...
2012-03-26 04:47:01,622 Rules.INFO Event: from 3:1 to 1:1, Report, value: [37, 0]
2012-03-26 04:47:01,621 Z-Wave.WARNING SOF found while awaiting ack...
2012-03-26 04:47:01,570 Z-Wave.WARNING CAN found while no job awaiting ACK..
And I've re-connected several times since the switch.
C
You probably have wrong timezone selected in your account
Got to your profile page and select correct timezone correspinding to your location. If you have UTC zone selected, it will not change between summer/winter. This is probably your case.
catman
Perfect
Post by catman »
Thanks!
