Remote control
foko
Remote control
Post by foko »
how do you get a device to work with a remote?
I've tried to put a switch into the group 1-2-3-4 but no matter what happens nothing when I press my remote.
Have tried with Innvous old 8 button remote and QEES new 4 button.
Can see in the log I press the button and make a 255 or 0
Make sure to appy changes.
The button is on the bottom of the page. Then wake up your remote (check the manual how to do it). The colour of the device to be controlled should become black in association group.
If you see 255 and 0 in logs, it means that association to your stick (Z-Cloud) is added. You can remove it if you want, since you don't need it for direct associations between remote and target node.
foko
I have try to "save" and
Post by foko »
I have try to "save" and Apply Confirguration for this device, but the device is red.
foko
it is working :-)
Post by foko »
it is working :-)
