Z-Cloud Error Response
crvchul
Post by crvchul »
Redownloading the Z-Connector Package solved my first problem and I can run Z-Agent. I don't know if it is correct that the Terminal says
Opening device...
Connecting to server...
Establishing SSL connection...
Performing SSL handshake...
Loop started
but "Your status in Z-Cloud" says "Your are connected to Z-Cloud".
When i click on this link it asks me to input my credentials but after that I get an error message
Error response
Error code 404.
Message: Command not found: /htdocs/index_admin.html.
Error code explanation: 404 = Nothing matches the given URI.
Is this a problem on my side?
There was a problem in Z
There was a problem in Z-Cloud a week ago. If the problm perstists for you, just make a new account or write us, so we can manually fix your problem.
crvchul
I created a new account and
Post by crvchul »
I created a new account and it worked. Thank you, but in the meantime I bought a Razberry as you may noticed ;)
They work nearly the same right? Just the automation feature is missing on the pi, which will be added the next month if I follow your words ;) Is there a way to get a beta for testing? Because I am working on an iOS Client and currently I rewrite a lot of code in the automation folder which maybe is unnecessary.
the release candidate is not
the release candidate is not available yet
