z-cloud error
michap
z-cloud error
Post by michap »
removing a defective device I have got the error:
Command not found:/ZWaveAPI/Run/devices/%5B14%5D.RemoveFailedNode()
BTW: Cloud is very very slow - already thought server is dead...
Michael
2013-07-11 12:09:37,734 WebSrv.ERROR Bad request /ZWaveAPI/Run/devices%5B14%5D.RequestNodeInformation(): Command not found: /ZWaveAPI/Run/devices%5B14%5D.RequestNodeInformation()
2013-07-11 12:09:37,734 Except.CRITICAL Error handling web request: /ZWaveAPI/Run/devices%5B14%5D.RequestNodeInformation()
2013-07-11 12:09:37,733 Except.CRITICAL KeyError: 14
2013-07-11 12:09:37,733 Except.CRITICAL File "", line 1, in
2013-07-11 12:09:37,733 Except.CRITICAL File "/var/pyzw/pyzw/WebServer.py", line 187, in do_POST
2013-07-11 12:09:37,732 Except.CRITICAL Traceback (most recent call last):
2013-07-11 12:09:37,698 Z-Wave.INFO Request NIF from a node: Request for node 6 information frame sent
2013-07-11 12:09:03,983 WebSrv.ERROR Bad request /ZWaveAPI/Run/devices%5B14%5D.RemoveFailedNode(): Command not found: /ZWaveAPI/Run/devices%5B14%5D.RemoveFailedNode()
2013-07-11 12:09:03,983 Except.CRITICAL Error handling web request: /ZWaveAPI/Run/devices%5B14%5D.RemoveFailedNode()
2013-07-11 12:09:03,983 Except.CRITICAL KeyError: 14
2013-07-11 12:09:03,982 Except.CRITICAL File "", line 1, in
2013-07-11 12:09:03,982 Except.CRITICAL File "/var/pyzw/pyzw/WebServer.py", line 187, in do_POST
2013-07-11 12:09:03,981 Except.CRITICAL Traceback (most recent call last):
2013-07-11 12:09:01,574 Rules.INFO Event: from 6:0 to 1:0, Report, value: [37, 0]
2013-07-11 12:09:01,374 Z-Wave.INFO Send to device 6, instance 0, switch bin
