RazBerry or Z-Box
md6a2
RazBerry or Z-Box
Post by md6a2 »
I am soon going to give a a try to Z-Way on a dedicated hardware (because Z-cloud looks promising enough and the documentation is top notch compared to many other ZWave boxes).
What would be the official recommandation from Z-wave.me : is it better to run Z-Way on a Raspberry with the Razberry daughter card or is the Z-Box running on an alix the best way ?
What would be the pros and cons of each one ?
Thank you in advance,
Miguel
Re: RaZberry or Z-Box
RaZberryPros:cheaperadditional pins of Raspberry Pi are still available for extensions and shieldswell maintained OS (Raspbian) with many other programsCons:Raspberry Pi is not suited for real production, but more for hackingcheap SD cards might get damaged by Raspberry Pi if power fails Z-BoxPros:good aluminium enclosurepowerful external antenna (with more than 2 times bigger range)Cons:priceno shields or other extensions available
