I have installed the razberry on the raspberry, and it it workin great. I have included multiple switches, sirens and sensors. But I'm wondering when or if you are going to add extra classes to the Razberry.
I have some gear from Bnext - Tag readers which use the : GENERIC_TYPE_ENTRY_CONTROL.
Can you let me know if you are going to add new classes and which ones these are and when they will be included in your software?
But this is a great solution for people who want to add zwave control in their own software without to create their own Zwave drivers or dont want to use Open-Zwave.
Ronald
Extra Zwave Classes
DoorLock and UserCode are
DoorLock and UserCode are comming this week. SceneActivation too.
Which CCs does your BeNEXT device support? If it is this one: http://www.pepper1.net/zwavedb/device/302 only UserCode and Alarm are missing right now. Alarm will certainly come soon too.
Looking better and better
rbmace, did you find documentation somewhere to help you get started coding for RaZberry? Can you tell us about the process of getting started?
PoltoS: Will documentation for RaZberry eventually be under the "documentation" tab of this site, or should I be looking for it somewhere else? Thank you for all your answers to questions.
It is on http://razberry
It is on http://razberry.zwave.me/docs.php. I understood the API docs will be updated this week
Extended docs on 60 pages will be out today or tomorrow
Extended docs on 60 pages will be out today or tomorrow. 20 pages more will come on weekends.
There are quite a lot to document
Yes, it will be on our site in Documentation section.
Poltos,
Poltos,
You are correct i am using the one you linked. Do you have an estimate when alarm will come?
Another question how can we update the raberry software? Running the install bash script again?
I would love to add the extra classes
Great software BTW!!!
Regards
Ronald
Regards
Ronald
I used the api documentation
I used the api documentation and i used the js decoder in firefox to see all the commands to the razberry json api. So you can see which command you must sent if you press a button on the demo Ui
Helped me alot
Ronald
Helped me alot
Ronald
New version is out! Run the
New version is out! Run the same install script again - it will find out the current software installed, make a backup and copy all your config from the old to new version.
Also note that UserCode has no UI yet, so you can only use scripting to try it.
Cant include new device - user code
Hi Poltos,
I tried to include the following device : http://www.pepper1.net/zwavedb/device/302
But if I want to add it to the razberry I dont see anything?
I run command : ZWaveAPI/Run/controller.AddNodeToNetwork(1)
Am I doing something wrong?
Regards
Ronald
Regards
Ronald
We have forgot to upload the
We have forgot to upload the database (from PepperOne) into the latest RaZberry. Please update again - it is included now.
