New version of RaZberry is released
sonnyboy
Wrong
Post by sonnyboy »
Wrong place
You are totally right.
tester
Anyone get V1.4 working?
Post by tester »
Glad to see a new version come out.
Has anyone been successful in upgrading to V1.4?
I updated to the new version with "wget -q -O - http://razberry.z-wave.me/install | sudo bash". Then I tried to run the software with "ipaddr:8083", but it did not work - no connection (but it had worked before the upgrade).
Suggestions?
sonnyboy
Mine is working just great
Post by sonnyboy »
But with this command
wget razberry.z-wave.me/install/v1.4-rc2-2-g120b777 -O - -q | sudo bash
And my previus problem seems to be gone :)
B0xY
After upgrade to V1.4
Post by B0xY »
I got the following error after upgrade to latest version:
z-way-server: error while loading shared libraries: libyajl.so.2: cannot open shared object file: No such file or directory
someone have the same problem?
Suggestions?
NiklasO
Same here.
Post by NiklasO »
Same here.
With the latest version:
pi@PiServer /opt/z-way-server $ ./z-way-server
./z-way-server: error while loading shared libraries: libzwayhttp.so: cannot open shared object file: No such file or directory
I did try the RC version:
./z-way-server: error while loading shared libraries: libyajl.so.2: cannot open shared object file: No such file or directory
Now the server won't start.
I used "wget -q -O - http://razberry.z-wave.me/install | sudo bash" to upgrade.
Reverting back to previous version works.
wizzard72
After installing v1.4 I had
Post by wizzard72 »
After installing v1.4 I had the following error:
I solved it to install::
sudo apt-get install libyajl2
Then reboot.
Error was reported for the
Error was reported for the Release Candidate. The work around has been published somewhere there. Apparantly the missing file did not make it into the final distro.
Please do
Please do
Or re-install the software - new installer now cares about the missing library.
Nejc
Hi
Post by Nejc »
Hi
I tested 1.4 version one month ago and I found some bugs. Today I reinstall on the last official 1.4 vesion and I got the same bugs like one month ago.
Bugs are: When I click on Device configuration -> Danfoss Living Connect 2.51 I get error: method_guilnit: values[] size differs from number of parameters. On Map side I can’t see background ground plan image. Also when I interview Danfoss Wall plug (FGWPE) I have problem with interviewing command class AlarmSensor.
Any suggestion how to fix these bugs? Any plan to fix this? Thanks in advance.
Regards,
Nejc
