Command line examples for switching
McD
Post by McD »
The start is always the hardest. Reading sensor data with the RaZberry already works fine, switching with z-way demo software as well, but automatisation with my custom installation still is not working.
I am looking for command line example for using the z-wave switches with the RaZberry.
Before implementation I would like to test these with curl, but my attempts failed so far.
Example:
With a statement of
$ /usr/bin/curl -LN http://_ip_address_:8083/ZWaveAPI/Data/1364468134
I receive a json string, which I can parse for the info I am looking for.
What is missing now, is what to send with curl to set the value of a switch to 255 (ON) or 0 (OFF)?
Thank you
McD
I found one solution...
Post by McD »
..just for helping others in the same situation.
What you read in the razberry.pdf on page 31 did not work with my setup. Nothing happend when I used ...Basic.Set(255) to switch on the lights...
On my system this here worked:
$curl -s -LN --globoff 'http://_ip_address_:8083/ZWaveAPI/Run/devices[2].instances[0].commandClasses[32].Set(255)'
>null
(This will switch on device 2)
$ curl -s -LN --globoff 'http://_ip_address_:8083/ZWaveAPI/Run/devices[2].instances[0].commandClasses[32].data.level.valueOf()'
>255
(This indicates the level (255=ON) for device 2)
$ curl -s -LN --globoff 'http://_ip_address_:8083/ZWaveAPI/Run/devices[2].instances[0].commandClasses[32].Set(0)'
>null
(This will switch off device 2)
> 0
(This indicates the level (0=OFF) for device 2)
McD
software update changed things...
Post by McD »
..after the software update today, these will only work, when using
..commandClasses[37]...
Why?
SpamNeinDanke
Command classes
Post by SpamNeinDanke »
Hi McD,
according to the command class descriptions ( http://wiki.micasaverde.com/index.php/Z ... nd_Classes ) you were using the CC BASIC. Now you are using SWITCH_BINARY which seems to be the correct command class for your purpose. I however do not know why the behavior changed in Z-Way.
BASIC should also be capable of doing what you origionally could as it has to implement ther functions ( http://wiki.zwaveeurope.com/index.php?t ... tion_Layer )
SET: set a value between 0 and 255 (0x00 …0xff);
GET: ask the device to report a value;
REPORT: response to the Get command. Reports a value between 0 and 255 (0x00 … 0xff);
Please post us the log using
Please post us the log using 32.
McD
...information and log
Post by McD »
I do
$ /usr/bin/curl -s -LN --globoff 'http://__ip_address__:8083/ZWaveAPI/Run/devices[X].instances[0].commandClasses[32].Set(255)'
and I receive this error message:
Uncaught TypeError: Cannot call method 'Set' of undefined
In the log file, after many many attempts to fill the JS buffer (please see other thread about this problem) I get this:
Executing script: zway.devices[X].instances[0].commandClasses[32].Set(255)
result: Error: Uncaught TypeError: Cannot call method 'Set' of undefined
Does this help?
(For finding a problem it would be really helpful to have an instant log file, which logs the events and messages in the order they appeared. Having this buffered JS log is a problem.)
dholland
It looks like you're using
Post by dholland »
It looks like you're using /Run/devices[X] instead of /Run/devices[2] in the above post. If that's true, it would throw the error.
