2Gig CT-100 Inteview Not Complete
kaptk2
Post by kaptk2 »
I have added a 2Gig z-wave thermostat (model CT-100) and it will not complete the inverview although it looks like it does. How can I go about troubleshooting this?
Thanks.
_
/- ndrew
We have never tested this
We have never tested this thermostat, since it is available only in US. What means "it will not complete the inverview although it looks like it does"? Do you miss some functionality from this deivce? Or it works, but the interview is not complete?
Please press on the Show Interview Results button and give us the list of non-finished interview. Also please paste us the nodeInfoFrame content from the device (press in Interview Results dialog on the device name and look on nodeInfoFrame value). I'm pretty sure this device have some Command Classes not implemented by RaZberry. We are implementing some of Command Classes used in US specific thermostats. We believe this release will be available in 10-14 days.
kaptk2
The device does not function.
Post by kaptk2 »
The list of uncompleted interviews is below:
1 SensorMultilevel
1 ThermostatMode
1 ThermostatSetPoint
1 MultiChannel
1 ManufacturerSpecific
1 Battery
1 Clock
1 Association
1 Version
2 SensorMultilevel
2 Association
The nodeInfoFrame:
devices.15.data: None (Friday, 14 June 14:21)
basicType: 4 (Saturday, 15 June 17:17)
genericType: 8 (Saturday, 15 June 17:17)
specificType: 6 (Saturday, 15 June 17:17)
infoProtocolSpecific: 5430272 (Saturday, 15 June 17:17)
deviceTypeString: General Thermostat V2 (Saturday, 15 June 17:17)
isVirtual: false (Friday, 14 June 14:21)
isListening: false (Saturday, 15 June 17:17)
isRouting: true (Saturday, 15 June 17:17)
isAwake: true (Friday, 14 June 14:21)
optional: true (Saturday, 15 June 17:17)
isFailed: false (Saturday, 15 June 17:17)
beam: false (Friday, 14 June 14:21)
sensor250: false (Saturday, 15 June 17:17)
sensor1000: true (Saturday, 15 June 17:17)
neighbours: (Saturday, 15 June 17:17)
manufacturerId: 152 (Saturday, 15 June 12:12)
vendorString: RTCA (Saturday, 15 June 12:12)
manufacturerProductType: 25601 (Saturday, 15 June 12:12)
manufacturerProductId: 262 (Saturday, 15 June 12:12)
ZWLib: 3 (12:38)
ZWProtocolMajor: 3 (12:38)
ZWProtocolMinor: 28 (12:38)
SDK: 5.03 (12:38)
applicationMajor: 9 (12:38)
applicationMinor: 0 (12:38)
nodeInfoFrame: 32,129,135,114,49,64,66,68,69,67,134,112,128,133,96 (Friday, 14 June 14:21)
ZDDXMLFile: 289-0098-6401-0015-00-03-1c-00-00.xml (12:35)
lastSend: 13742071 (12:59)
lastNonceGet: None (Saturday, 15 June 17:17)
lastReceived: 0 (12:59)
failureCount: None (12:59)
keepAwake: false (Saturday, 15 June 17:17)
countSuccess: 0 (Friday, 14 June 14:21)
countFailed: 0 (Friday, 14 June 14:21)
queueLength: 0 (Friday, 14 June 14:21)
Are you saying that in 10-14 days this device will be fully functional?
kaptk2
Bump... Any help on this?
Post by kaptk2 »
Bump...
Any help on this?
We are testing Radio
We are testing Radio Thermostat CT100 device. Seems to be same as yours. It passes 90% of the interview out of the box, but still some minor stuff is missing. NExt release will have compleate support of theses devices.
Does your device passes at leas some Command Classes interview?
kaptk2
The interview passes
Post by kaptk2 »
The interview passes everything except for these four items:
1 SensorMultilevel
1 Association
2 SensorMultilevel
2 Association
As a result I am unable to control the settings. Is that what you are seeing as well?
No, the device we have does
No, the device we have does not have instances (1 and 2 as yours do). So, we can not check this.
Please send us interview log by email and we will check it.
kaptk2
Retriving the interview log
Post by kaptk2 »
How do I get the interview log to send via email? I just updated the firmware tonight and this is still not working.
You need to send us the log (
You need to send us the log (/var/log/z-way-server.log) made since the re-interview process.
By the way, Association class is not allowed under channels - this is clearly a bad design!
poshul
RT101 Interview issues
Post by poshul »
Hi, I have an RT101 and am having similar issues (the RT101 is a bebadged RT100 sold through Lowes on their iris system). The interview process initially fails after Manufacturer-specific, and version, but I can force re-interview of all of the other classes besides multichannel. Here's the generated record:
0
