failed to discover ZWay: -9
pawelk
Post by pawelk »
I could not get one of my RaZberry working. After astarting z-way server there is a ton of log messages (in /var/z-way-server.log) and things ends with:
[2013-06-21 15:27:30.597] CC "ApplicationStatus" is not implemented
[2013-06-21 15:27:30.598] Adding job: Set controller node information frame
[2013-06-21 15:27:30.599] No controller device found
[2013-06-21 15:27:30.599] Removing job: Get initial data about network devices
[2013-06-21 15:27:30.601] SENDING (cb 0x01): ( 01 04 00 62 01 98 )
Z-Way version v1.3.1 from 2013-05-19 23:54:27 +0400 (build e717f1057ab76a00fa02d9e6546e360ad3390f36)
after this z-way-server quits . Full log from one run of z-way is here:
http://lib.pia.org.pl/~pkj/z-way-server.log
Do you have any ideas?
Your Raberry have wrong data
Your Raberry have wrong data in memory. Ususally this is checked during quality control, but may be someone forgot to do it. It happens - we will investigate the issue.
Your problem is in thse lines:
[2013-06-21 15:27:10.947] SETDATA controller.data.nodeId = 255 (0x000000ff)
[2013-06-21 15:27:10.947] SETDATA controller.data.homeId = -1 (0xffffffff)
This means you need to reset the memory content.
To do it please shout down Z-Way: /etc/init.d/Z-Way stop
Reset RaZberry: echo -ne "x01x04x00x42x01xB8" > /dev/ttyAMA0
Start Z-Way back: /etc/init.d/Z-Way start
Please report if this helped
rabing
same her right after "apt-get upgrade"
Post by rabing »
uname -a: Linux 3.6.11+ #474 PREEMPT Thu Jun 13 17:14:42 BST 2013 armv6l GNU/Linux
== log ========
[2013-06-24 15:28:03.534] SETDATA controller.data.nodeId = 0 (0x00000000)
[2013-06-24 15:28:03.534] SETDATA controller.data.homeId = 0 (0x00000000)
[2013-06-24 15:28:03.537] SETDATA controller.data.softwareRevisionVersion = "v1.3.1"
[2013-06-24 15:28:03.537] SETDATA controller.data.softwareRevisionId = "e717f1057ab76a00fa02d9e6546e360ad3390f36"
[2013-06-24 15:28:03.538] SETDATA controller.data.softwareRevisionDate = "2013-05-19 23:54:27 +0400"
[2013-06-24 15:28:03.538] SETDATA controller.data.functionClasses = int[43]
[2013-06-24 15:28:03.551] Opened device: /dev/ttyAMA0
[2013-06-24 15:28:03.552] Worker thread successfully created
[2013-06-24 15:28:03.553] Worker thread entry point
[2013-06-24 15:28:03.563] Adding job: Get controller info and supported function classes
[2013-06-24 15:28:03.566] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2013-06-24 15:28:03.577] RECEIVED ACK
[2013-06-24 15:28:03.588] RECEIVED: ( 01 2B 01 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D2 )
[2013-06-24 15:28:03.590] SENT ACK
[2013-06-24 15:28:03.590] SETDATA controller.data.APIVersion = "00.00"
[2013-06-24 15:28:03.590] SETDATA controller.data.manufacturerId = 0 (0x00000000)
[2013-06-24 15:28:03.591] SETDATA controller.data.manufacturerProductType = 0 (0x00000000)
[2013-06-24 15:28:03.591] SETDATA controller.data.manufacturerProductId = 0 (0x00000000)
[2013-06-24 15:28:03.594] SETDATA controller.data.vendor = ""
[2013-06-24 15:28:03.594] Supported Function Classes:
[2013-06-24 15:28:03.594] ---------------------------
[2013-06-24 15:28:03.594] SETDATA controller.data.capabilities = int[0]
[2013-06-24 15:28:03.595] Job 0x07 (Get controller info and supported function classes): success
[2013-06-24 15:28:03.595] Get Serial API Capabilities returned zero.
[2013-06-24 15:28:03.595] Removing job: Get controller info and supported function classes
rabing
fixed: the razberry board needed a reset
Post by rabing »
since I could not "talk" to razberry board, pulling the powerplug did the job.
mstragowski
similar problem here but not the same
Post by mstragowski »
My raZberry module starts with home id 0xffffffff and Z-Way server works but it is showing 231 devices paired (all dead) and there is nothing i can do with this module, i can't do a factory reset and the command you provided for pawelk - does not work in my case
Try to reset the device using
Try to reset the device using the button in Network Management tab (in Expert mode, on the bottom).
If this does not help, may be the device has damaged EEPROM. This is subject to RMA.
brent192
Nevermind...it suddenly
Post by brent192 »
Nevermind...it suddenly started working. Strange.
brent192
Same problem...
Post by brent192 »
I just got my new Razberry and I am having the same issue. I did the memory reset and the service still wont start up. Any ideas?
