error 500 for http request
pcthx51
Post by pcthx51 »
hello ,
i'm newbie on the forum... and i really don't speak well !
I explain my problem :
i've 3 duwi blind control with zwave.me modified firmware and 1 duwi original blind control.
with the web interface or the zway apps for ios, i can't open or close the 4 blinds !
but with http request, i've a problem with the last peripheral !
one of the 3 zwave.me modified firmware is node 2
the http command : http://localhost:8083/ZWaveAPI/Run/devi ... asic.Set(0 or 255) return me a response OK
but the http command : http://localhost:8083/ZWaveAPI/Run/devi ... asic.Set(0 or 255) return me a response "internal sever error"
i notify that device 8 is the duwi blind control with original firmware
What is written in the log?
What is written in the log? May be interview was not complete for that device?
pcthx51
hello, thanks for your
Post by pcthx51 »
hello, thanks for your response !
i've find the mistake with a friend .
the duwi blind control with no modified firmware can't be piloted with the basic command class...
So i just use the command class 38 (switchbinarylevel) and it's ok !!!
