Hi!
I have some z-wave devices with proprietary class commands.
I am using the RaZberry to communicate and manage the z-wave devices on my network.
It is possible to integrate the proprietary commands with z-way?
Proprietary class commands
Yes, if you know how to
Yes, if you know how to operate with them. Do you know the proprietary protocol?
Isn't it the Danfoss Living Connect?
I do not have yet those
I do not have yet those commands, but for sure I will have access in a short time.
I know that configuration is stored thought the command class COMMAND_CLASS_CONFIGURATION (0x70).
There is any way to get the byte frame, response from the z-wave device, thought the z-way API?
Configuration Command Class
Configuration Command Class can be managed using our UI, you do not need to trap frames to use it.
