Mini Demo UI
S1N82
Mini Demo UI
Post by S1N82 »
I have a problem with the Mini UI.
- Installed razberry software
- Added one switch using the original UI
- Downloaded Mini UI
Switch is shown but i get the following exception:
exception in triggerPath event: TypeError: obj is null
--> jquery.triggerpath.js:245
Any hints?
Which URL do you use?
S1N82
URL
Post by S1N82 »
Downloaded UI from
- https://github.com/PoltoS/z-way-mini-ui
Moved folder to htdocs and tried:
- http://IP:8083/z-way-mini-ui-master/z-way-demo.html
Renamed z-way-ui folder to htdocs:
- http://IP:8083/z-way-demo.html
Also tried to rename the file to index.html:
- http://IP:8083
The UI can be opened from any
The UI can be opened from any folder (even from a folder on another computer). But you need to enter the URL to the server.
Epsilon159
A problem with Mini UI
Post by Epsilon159 »
I have also a problem with the Mini UI:
I open it from another computer and I use http://IP:8083 URL. The server is reached but I can't see any of my devices (a switch and a sensor that I have included with the Expert UI).
In the Javascript console in Chrome, I've got the message:
"exception in triggerPath event: TypeError: Cannot read property 'value' of undefined" jquery.triggerpath.js:245
Any idea?
Thank you very much.
Wee need to know Z-Way
Wee need to know Z-Way version and what devices are in your network (may be a backup of your network). We will change the mini UI soon, so may be it is not worth to spare time.
