Few problems with v. 1.4 (1.3.1 as well )
LOCOSP
Post by LOCOSP »
Hi community,
I am noob :) but i did little research and didn't find anything about my problems so decided to ask You guys.
1. I've included my Fibaro Relay Switch 2x1.5kW FGS221 2.1 - 2.3 and it is but only 20 seconds.
When I will turn on one or both switches stay turned on only for 20 sec and than getting off ??
where is the problem?
Where can i disable that auto thing ?
2. this problem was as well in 1.3.1 and 1.4 when I try to rename my device it is renamed but only for the "session" , when I'll reload page it is again for example "Device4". I did "apply changes for this device"...
3.When i try to use button "switch all on/off" a get error message like this http://locosp.dyndns.org/blog-grafika/r ... /error.png
4. Maybe I don't know much about it bu I think here http://locosp.dyndns.org/blog-grafika/r ... razpis.png should be only one position, or no ?
5. Is it normal that "change device type" do nothing ? http://locosp.dyndns.org/blog-grafika/r ... getype.png ?
6. I think last :) how can I totally reset all configurations ( master reset ) ?
Sorry for my English ...
Thank You in advance
regards
LOCOSP
sonnyboy
1.
Post by sonnyboy »
Try to force re interwiew and it will work again, i had the same problem with 1 wallplug
1. May be you have configured
1. May be you have configured auto off function? Or may be you have some JS code that switches it off back? Check logs.
2. Make sure to press Save button on the Map tab.
3. Fixed for net version - button removed ;)
4. That's ok, there should be three groups.
5. Fixed! Button removed ;)
6. Network->Reset Controller
LOCOSP
@sonnyboy @PoltoS thanks guys
Post by LOCOSP »
@sonnyboy @PoltoS thanks guys but it was my fault, because module was incorrectly paired [ solved ] :)
@PoltoS about second issue: the "save" button is always inactive...
What i do:
- select the device i want to change name
-clicking "rename device"
-changing the name and pressing OK
and this "save" button on the left side from "Rename device" is inactive all the time ?! ...
sonnyboy
Go to map tab.
Post by sonnyboy »
If you go to map tab i think the save button is aktivated :)
LOCOSP
Yest thank You it's working
Post by LOCOSP »
Yest thank You it's working :D.
Last question: what is the difference between glowing bulb and gray bulb ( gray is workin everythin fine ) ?
peace
Borys
