I wanted to know if you have provided a mechanism for cleaning logs ? Because the log file grown much bigger and fill the filesystem (more than 1go).
Prevent log size
Re: Prevent log size
You best bet is to probably to use Logrotate. http://www.thegeekstuff.com/tag/debian-logrotate/
Yes but I think an option to configure zway (like log level : Debug, Error) it's good idea and It can improve perf au zway (raspberry pi is very very slow to write file on SD card).
Edit :
I found this option : Use log-level 6 and http-log-level 4 in /opt/z-way-server/config.xml
Edit :
