Fibaro Roller Shutter 2 FGRM-222
Mike_77
Post by Mike_77 »
trying to insert and use the roller shutter I could not finish the interview.
I got the Error message:
method_guiInit: values[] size differs from number of parameters!
Trying to recieve the configuration parametes was also not succesfully.
The Roller shuter is in the list of released devices.
What is the problem?
pofs
Re: Fibaro Roller Shutter 2 FGRM-222
Post by pofs »
I think there's some problem with device XML.
Try updating them first, probably it is already fixed:
cd /opt/z-way-server/ZDDX
./UpdateXMLs.sh
Update: well, the file appears to be very wrong, as it previously was for FGMS-001.
To fix it, you need to replace type "constant" to "rangemapped" in all parameters, and then correct some ranges according to the manual.
Mike_77
Post by Mike_77 »
I'm getting several errors during the update for following XML files
Error loading Z-Wave Device Description XML 537-0109-2005-0505-03-03-83-14-03.xml: list index out of range
Error loading Z-Wave Device Description XML 290-0068-0000-0000-00-02-4e-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 512-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 409-0123-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 345-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 550-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 446-0128-0128-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 440-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 109-0002-0000-0000-00-00-00-00-00.xml: list index out of range
Error loading Z-Wave Device Description XML 547-0109-2001-0105-03-03-92-05-01.xml: list index out of range
Error loading Z-Wave Device Description XML 507-0109-2005-0505-03-03-53-0e-01.xml: list index out of range
Error loading Z-Wave Device Description XML 466-0000-0000-0000-00-00-00-00-00.xml: list index out of range
Roller shutter still not fully supported.
Any another idea?
pofs
Post by pofs »
Errors are okay (there are some incomplete files).
As I wrote, the file is currently broken. You may fix it yourself though ;)
Just replacing "constant" with "rangemapped" everywhere in 492-010f-0301-1001-03-03-34-16-16.xml should fix page display, but some parameters might have wrong ranges.
SolarFlor
Post by SolarFlor »
Any progress on this?
My friend Dolan (see discussion in Italian) have a problem with this Roller Shutter that is seen by Z-Way as a switch and not as a sensor
Indeed it presents itself as a switch. This is a break of Z-Wave rules IMHO.... May be do reinterview after calibration (request NIF before)
prytnar
Post by prytnar »
Anybody was able to make this roller shutter working with Zwave ? Is there any blogpost about it ?
After connecting it I can only hear short blip in device and nothing happens with roller.
Also:
Why it shows that my device seems to be dead ?
Why it shows that roller is closed when it is up ? Even after request for NIF was successful ?
thaui
Post by thaui »
I have the same behaviour. A short relais blip and nothing happens. No idea what I need to change. Anybody out there where it works?
