Info
mikes
Info
Post by mikes »
Kindly ask if you can do the Italian version of z wave me, I know we are in a few .... But surely it will expand in the future Thanks to all Mike: D
Re: Info
That is a community job I think. At the bottom of this post viewtopic.php?f=3417&t=19742&p=47780&hi ... ons#p47780, you can see some localisation instructions. Don't know if that is still valid
mikes
Re: Info
Post by mikes »
hello and thank you, I entered the Italian js file in / opt / z-way-server / htdocs / expert / js
but now I'm stuck, I can not ada go forward, that step I'm missing??
Thanks to all for the help
Re: Info
You need to mention it in the main file. May be you can send it to us and we will include it in the next release?
Also translations of find.z-wave.me would be cool ;)
There are only few:
var lang_err = { eng: { "50x": "An error has occured during connection to your Z-Way",
"bad_login": "Remote access not possible or wrong password" },
var lang_mess = { eng: { caption: { "innerHTML": "Z-Way Remote Access",
"style": { "fontSize": "24px" } },
user_field: { "placeholder": "Z-Box ID" },
pass_field: { "placeholder": "Password" },
submit_but: { "value": "Log In" },
diruris_box_caption: { "innerHTML": "Direct connect to Z-Way:" },
http_msg_text:{ "innerHTML": "Not a secure connection" },
https_msg_text:{ "innerHTML": "Secure connection" } },
SolarFlor
Re: Info
Post by SolarFlor »
PoltoS wrote:You need to mention it in the main file. May be you can send it to us and we will include it in the next release?
There are only few:
var lang_err = { eng: { "50x": "Si è verificato un errore durante la connessione al tuo Z-Way",
"bad_login": "Accesso remoto non consentito o password errata" },
var lang_mess = { eng: { caption: { "innerHTML": "Accesso Remoto Z-Way",
diruris_box_caption: { "innerHTML": "Connessione Diretta a Z-Way:" },
http_msg_text:{ "innerHTML": "Connessione non sicura" },
https_msg_text:{ "innerHTML": "Connessione Sicura" } },
Translated
SolarFlor
Re: Info
Post by SolarFlor »
You mean we could add to the existing files the it tranlsation like below and than send to you, right?
<Event id="0x03">
			<name>
				<lang xml:lang="en">Water level dropped</lang>
				<lang xml:lang="de">Wasserstand fällt</lang>
				<lang xml:lang="ru">Уровень воды упал</lang>
				<lang xml:lang="it">Livello dell'acqua è sceso</lang>
Re: Info
Thanks, find.z-wave.me IT translation added!
About other: New UI still have no translation to other languages. This is a work to do.
Blue UI needs language.it.js to be translated, but I would prefer to wait for the new version of the UI before translating it.
String values in Z-Wave data holders are taken from translations/ folder. But in most cases these values are not used.
SolarFlor
Re: Info
Post by SolarFlor »
PoltoS wrote: Blue UI needs language.it.js to be translated, but I would prefer to wait for the new version of the UI before translating it.
Where is this file? we could support to translate it
mikes
Re: Info
Post by mikes »
hello I think you have to create the file in ita here
/opt/z-way-server/htdocs/expert/js
SolarFlor
Re: Info
Post by SolarFlor »
You are right
