I have an issue with include/exclude mode, when I click on the button it does nothing. But if I look zway three it's ok the controller is in include/exclude mode. The only way to repaire that it's to restart z-way-server. I used 1.7.2, is it know issue ?
Thank in advance.
Can not entering in include/exclude mode
Re: Can not entering in include/exclude mode
It works fine for me in 1.7.2. I had to do quite a lot of re-includes of my two Fibaro Universal sensors lately. As a check, I did switch to Expert mode, where I activated the Inspect queue window to monitor the inclusion progress.
I have already the error, but if I wait 1min-1min30 the zway send me event for switch to exclude mode. So it's work but it's very very slow. It's a bug zway network maybe it's due to that. But when I restrart the zway it's instant.
Here the log :
[2014-09-02 16:40:10.972] Executing script: zway.controller.RemoveNodeFromNetwork(1)
[2014-09-02 16:40:10.973] Adding job: Remove node from network
[2014-09-02 16:40:10.977] SENDING (cb 0xf3): ( 01 05 00 4B 81 F3 C3 )
[2014-09-02 16:40:10.988] RECEIVED ACK
[2014-09-02 16:40:10.998] RECEIVED: ( 01 07 00 4B F3 01 00 00 41 )
[2014-09-02 16:40:10.998] SENT ACK
[2014-09-02 16:40:10.998] SETDATA controller.data.lastIncludedDevice = Empty
[2014-09-02 16:40:10.999] SETDATA controller.data.lastExcludedDevice = Empty
[2014-09-02 16:40:10.999] Job 0x4b (Remove node from network): Ready to remove - push button on the device to be removed
[2014-09-02 16:40:10.999] SETDATA controller.data.controllerState = 5 (0x00000005)
Here the log :
