Linear GD00Z-X Garage Door Opener
Re: Linear GD00Z-X Garage Door Opener
What is the next step to getting this device working???
Well, it should work right after inclusion.
You may use expert commands to send requests to the device, or just do it from JS:
It also seems to have audible notification, so you can also turn it on/off:
open: http://ip:8083/ZWaveAPI/Run/devices[x].BarrierOperator.Set(255)
close: http://ip:8083/ZWaveAPI/Run/devices[x].BarrierOperator.Set(0)
on: http://ip:8083/ZWaveAPI/Run/devices[x].BarrierOperator.SignalSet(1, 255)
off: http://ip:8083/ZWaveAPI/Run/devices[x].BarrierOperator.SignalSet(1, 0)
I can confirm those open/close commands do work.
Is there a tutorial for Expert Commands and Java Script?
I thought I saw a JS Module in HA, can I use that?
I second these commands work. I have the Iris version from Lowes. (GD00Z-1) If I get some time I'll modify the UI to include a door type. Probably just the mobile UI. I'm sure they will officially add functionality at some point.evergreen wrote:I can confirm those open/close commands do work.
http://192.168.5.76:8083/ZWaveAPI/Run/devices[26].BarrierOperator.Set(0)
http://192.168.5.76:8083/ZWaveAPI/Run/devices[26].BarrierOperator.Set(255)
Is there a command to check if the door is open or closed?
Sure, there's a .Get() method for that, and device itself might send unsolicited reports about its state when opened or closed. State is stored in and could be read from devices[x].BarrierOperator.data.state.value.
I am able to query the GD00Z-4 using 2.0.1r16 but I'm not able to open or close it. This is only the second thing I've connected to it, so I'm not sure if I'm doing something wrong. (My lock works!)
http://localhost:8083/ZWaveAPI/Run/devi ... erOperator
gives me:
But POSTing to these URLs doesn't seem to do anything:
http://localhost:8083/ZWaveAPI/Run/devi ... r.Set(255)
http://localhost:8083/ZWaveAPI/Run/devi ... tor.Set(0)
gives me:
"name": "BarrierOperator",
"data": {
"1": {
"invalidateTime": 1425359746,
"updateTime": 1425359747,
"type": "empty",
"value": null,
"signalTypeString": {
"type": "string",
"value": "Audible notification"
"state": {
"type": "int",
"value": 0
"2": {
"type": "empty",
"value": null,
"type": "string",
"value": "Visual notification"
"state": {
"type": "int",
"value": 0
"invalidateTime": 1425354840,
"updateTime": 1425354841,
"type": "empty",
"value": null,
"supported": {
"type": "bool",
"value": true
"version": {
"invalidateTime": 1425357148,
"updateTime": 1425359749,
"type": "int",
"value": 1
"security": {
"type": "bool",
"value": true
"interviewDone": {
"type": "bool",
"value": true
"interviewCounter": {
"type": "int",
"value": 9
"state": {
"invalidateTime": 1425359747,
"updateTime": 1425413333,
"type": "int",
"value": 0
"signalMask": {
"updateTime": 1425357015,
"type": "binary",
"value": [
3
"id": 102
did u put the battery in door position sensor?
this is what your command gives me...
{"name":"BarrierOperator","data":{"invalidateTime":1424842353,"updateTime":1424842354,"type":"empty","value":null,"supported":{"invalidateTime":1424842353,"updateTime":1424842354,"type":"bool","value":true},"version":{"invalidateTime":1425058896,"updateTime":1425058898,"type":"int","value":1},"security":{"invalidateTime":1424842353,"updateTime":1424842354,"type":"bool","value":true},"interviewDone":{"invalidateTime":1424842353,"updateTime":1425058863,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1424842353,"updateTime":1424842354,"type":"int","value":10},"state":{"invalidateTime":1425182511,"updateTime":1425519622,"type":"int","value":255},"signalMask":{"invalidateTime":1425058861,"updateTime":1425058862,"type":"binary","value":[3]},"1":{"invalidateTime":1425058862,"updateTime":1425058863,"type":"empty","value":null,"signalTypeString":{"invalidateTime":1425058862,"updateTime":1425058863,"type":"string","value":"Audible notification"},"state":{"invalidateTime":1425058862,"updateTime":1425058863,"type":"int","value":0}},"2":{"invalidateTime":1425058862,"updateTime":1425058863,"type":"empty","value":null,"signalTypeString":{"invalidateTime":1425058862,"updateTime":1425058863,"type":"string","value":"Visual notification"},"state":{"invalidateTime":1425058862,"updateTime":1425058863,"type":"int","value":0}}},"id":102}
FYI there are a few status values that are used by the devicepofs wrote:Sure, there's a .Get() method for that, and device itself might send unsolicited reports about its state when opened or closed. State is stored in and could be read from devices[x].BarrierOperator.data.state.value.
0x00 (0) = closed
0xFC (252) = opening
0xFD (253) = unknown
0xFE (254) = closing
0xFF (255) = open
