Problem with install
thorbj
Post by thorbj »
Hi, I have a problem with installing RaZberry.
I've installed the Raspbian using the NOOBS installer from http://www.raspberrypi.org/downloads/, updated it using sudo apt-get update, and installed RaZberry using wget -q -O - razberry.z-wave.me/install | sudo bash
Now I get into the configuration service to change passord for the find.z-way.me service. But When I have changed the password, and waited 10 seconds for the changes to finsih, I can't access the UI at port 8083. I only get a message saying "The page is not available". I try then to stop the z-way server using sudo service z-way-server stop, but this gives me the following error: Stopping z-way-server: start-stop-daemon: warning: failed to kill 5282: No such process
What is going on here? What can I be doing wrong?
Thanks!
thorbj
Re: Problem with install
Post by thorbj »
Hmm, never mind. Did a reboot of the Pi, and it seemed to solve the problem...
