Updated to v2.0.0 Automation works but still no Expert view
slockyer
Post by slockyer »
Hi
I have updated to v2.0.0 and have a problem with viewing the expert page, menus show but all I get is "Error handling data from server". If I check z-way-server.log I can see communications with the Razberry e.g.
[2014-12-11 11:54:38.772] [D] [zway] SENDING: ( 01 04 00 62 11 88 )
[2014-12-11 11:54:38.774] [D] [zway] RECEIVED ACK
[2014-12-11 11:54:38.776] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2014-12-11 11:54:38.777] [D] [zway] SENT ACK
The Home Automation page loads fine and I can even see real-time information for my devices. I have checked that the binding is in place (even disabled it to verify that the messages stop in the log), rebooted countless times and even re-installed but still have the same problem.
In addition, I went back to v1.7.2 but that will not now load the expert page. I suspect I am doing something really stupid as a search on the board only reveals recommendations about adding the binding module on pre-release candidates so am back now on v2.0.0.
The Z-wave Binding shows /dev/ttyAMA0 with internal name zway.
Any help would be fantastic.
Thanks in advance.
Re: Updated to v2.0.0 Automation works but still no Expert v
Make sure to clear cache in browser.
slockyer
Post by slockyer »
Thank you for the input but tried that with no luck. Also tried FF Safari and Chrome but the same with cleared cache. I also used a fresh install of wheezy then installed z-way and found that the expert view worked but only for about an hour. During update of names it reverted to "Error handling data...".
Is there anywhere to look for issues seeing as it is clearly communicating with the razberry but not collecting data for the expert view?
Thanks,
Simon
