Restart error
pierre2302
Restart error
Post by pierre2302 »
Hello
I have a problem of restart with z-way-serveur. When I try to acceder in the interface, I have this message which displays :
" sorry server has not completely started yet. Try reloading the interface to later. "
I have the version v2.0.1-rc2 with razberry
[2014-12-19 07:41:15.328] [core] Executing script: exit()
[2014-12-19 07:41:46.989] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2014-12-19 07:41:47.196] [core] Executing script: // This script transforms old formats to new ...
[2014-12-19 07:41:47.233] [core] Executing script: ;!function(exports, undefined) { ...
[2014-12-19 07:41:47.576] [core] Executing script: // Underscore.js 1.6.0 ...
[2014-12-19 07:41:47.872] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2014-12-19 07:41:47.909] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2014-12-19 07:41:48.141] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2014-12-19 07:41:48.199] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2014-12-19 07:41:48.223] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2014-12-19 07:41:48.274] [I] [core] Executing script: /*** Main Automation webserver module ***************************************** ...
[2014-12-19 07:41:48.301] [I] [core] Executing script: // Make this testable by pulling in underscore from the parent module ...
[2014-12-19 07:41:48.339] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2014-12-19 07:41:48.543] [I] [core] --- Loading ZAutomation classes
[2014-12-19 07:41:49.095] [I] [core] Starting ZWay Automation webserver
[2014-12-19 07:41:49.132] [I] [core] Loading modules...
[2014-12-19 07:41:49.193] [I] [core] Loading module NotificationSMSru from modules/NotificationSMSru
[2014-12-19 07:41:49.214] [I] [core] Executing script: /*** NotificationSMSru Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.268] [I] [core] Loading module CodeDevice from modules/CodeDevice
[2014-12-19 07:41:49.308] [I] [core] Executing script: /*** CodeDevice Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.327] [I] [core] Loading module Cron from modules/Cron
[2014-12-19 07:41:49.334] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2014-12-19 07:41:49.550] [I] [core] Notification: error (core): Failed to load module SensorsPolling because Cron was not instanciated
[2014-12-19 07:41:49.551] [I] [core] Loading module TagOnOff from modules/TagOnOff
[2014-12-19 07:41:49.558] [I] [core] Executing script: /*** TagOnOff Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.560] [I] [core] Loading module OpenWeather from modules/OpenWeather
[2014-12-19 07:41:49.580] [I] [core] Executing script: /*** OpenWeather Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.582] [I] [core] Loading module HomeKitGate from modules/HomeKitGate
[2014-12-19 07:41:49.603] [I] [core] Executing script: /* ...
[2014-12-19 07:41:49.624] [I] [core] Loading module ImportRemoteHA from modules/ImportRemoteHA
[2014-12-19 07:41:49.632] [I] [core] Executing script: /*** ImportRemoteHA Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.635] [I] [core] Loading module HTTPDevice from modules/HTTPDevice
[2014-12-19 07:41:49.662] [I] [core] Executing script: /*** HTTPDevice Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.668] [I] [core] Loading module DummyDevice from modules/DummyDevice
[2014-12-19 07:41:49.678] [I] [core] Executing script: /*** DummyDevice Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.687] [I] [core] Loading module BindDevices from modules/BindDevices
[2014-12-19 07:41:49.694] [I] [core] Executing script: /*** BindDevices Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.718] [I] [core] Loading module Camera from modules/Camera
[2014-12-19 07:41:49.724] [I] [core] Executing script: /*** Camera Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.790] [I] [core] Loading module CustomUserCode from modules/CustomUserCode
[2014-12-19 07:41:49.799] [I] [core] Executing script: /*** CustomUserCode ZAutomation module **************************************** ...
[2014-12-19 07:41:49.801] [I] [core] Loading module LightScene from modules/LightScene
[2014-12-19 07:41:49.819] [I] [core] Executing script: /*** LightScene Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.827] [I] [core] Loading module CustomUserCodeLoader from modules/CustomUserCodeLoader
[2014-12-19 07:41:49.842] [I] [core] Executing script: /*** CustomUserCodeLoader ZAutomation module **************************************** ...
[2014-12-19 07:41:49.844] [I] [core] Loading module AutoLock from modules/AutoLock
[2014-12-19 07:41:49.858] [I] [core] Executing script: /*** AutoLock Z-Way Home Automation module ************************************* ...
[2014-12-19 07:41:49.868] [I] [core] Loading module SmartLight from modules/SmartLight
[2014-12-19 07:41:49.874] [I] [core] Executing script: /*** SmartLight Z-Way Home Automation module ************************************* ...
[2014-12-19 07:41:49.890] [I] [core] Loading module SensorValueLogging from modules/SensorValueLogging
[2014-12-19 07:41:49.900] [I] [core] Executing script: /*** SensorValueLogging Z-Way Home Automation module ************************************* ...
[2014-12-19 07:41:49.905] [I] [core] Loading module OpenRemoteHelpers from modules/OpenRemoteHelpers
[2014-12-19 07:41:49.924] [I] [core] Executing script: /* RaZOR ...
[2014-12-19 07:41:49.930] [I] [core] Loading module Notification from modules/Notification
[2014-12-19 07:41:49.935] [I] [core] Executing script: /*** Notification Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.947] [I] [core] Loading module Cron from modules/Cron
[2014-12-19 07:41:49.948] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2014-12-19 07:41:49.955] [I] [core] Loading module SecurityMode from modules/SecurityMode
[2014-12-19 07:41:49.973] [I] [core] Executing script: /*** SecurityMode Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.983] [I] [core] Loading module YandexProbki from modules/YandexProbki
[2014-12-19 07:41:49.990] [I] [core] Executing script: /*** YandexProbki Z-Way HA module ******************************************* ...
[2014-12-19 07:41:49.992] [I] [core] Loading module LogicalRules from modules/LogicalRules
[2014-12-19 07:41:50.016] [I] [core] Executing script: /*** LogicalRules Z-Way HA module ******************************************* ...
[2014-12-19 07:41:50.019] [I] [core] Loading module Cron from modules/Cron
[2014-12-19 07:41:50.020] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2014-12-19 07:41:50.048] [I] [core] Notification: error (core): Failed to load module BatteryPolling because Cron was not instanciated
[2014-12-19 07:41:50.056] [I] [core] Loading module ZWave from modules/ZWave
[2014-12-19 07:41:50.104] [I] [core] Executing script: /*** Z-Wave Binding module ******************************************************** ...
[2014-12-19 07:41:50.125] [I] [core] Loading module ThermostatDevice from modules/ThermostatDevice
[2014-12-19 07:41:50.135] [I] [core] Executing script: /*** ThermostatDevice Z-Way HA module ******************************************* ...
[2014-12-19 07:41:50.146] [I] [core] Loading module GroupDevices from modules/GroupDevices
[2014-12-19 07:41:50.151] [I] [core] Executing script: /*** GroupDevices Z-Way HA module ******************************************* ...
[2014-12-19 07:41:50.153] [I] [core] Loading module ScheduledScene from modules/ScheduledScene
[2014-12-19 07:41:50.163] [I] [core] Executing script: /*** ScheduledScene Z-Way HA module ******************************************* ...
[2014-12-19 07:41:50.168] [I] [core] Loading module RoundRobinScenes from modules/RoundRobinScenes
[2014-12-19 07:41:50.177] [I] [core] Executing script: /*** RoundRobinScenes Z-Way HA module ******************************************* ...
[2014-12-19 07:41:50.181] [I] [core] Loading module SensorsPollingLogging from modules/SensorsPollingLogging
[2014-12-19 07:41:50.197] [I] [core] Executing script: /*** SensorsPollingLogging Z-Way HA module ******************************************* ...
[2014-12-19 07:41:50.199] [I] [core] Loading module SwitchControlGenerator from modules/SwitchControlGenerator
[2014-12-19 07:41:50.217] [I] [core] Executing script: /*** SwitchControlGenerator Z-Way HA module ******************************************* ...
[2014-12-19 07:41:50.220] [I] [core] Loading module RGB from modules/RGB
[2014-12-19 07:41:50.281] [I] [core] Executing script: /*** RGB Z-Way HA module ******************************************* ...
[2014-12-19 07:41:50.287] [I] [core] Loading module DelayedScene from modules/DelayedScene
[2014-12-19 07:41:50.295] [I] [core] Executing script: /*** DelayedScene Z-Way HA module ******************************************* ...
[2014-12-19 07:41:50.302] [I] [core] Loading module AutoOff from modules/AutoOff
[2014-12-19 07:41:50.310] [I] [core] Executing script: /*** AutoOff Z-Way Home Automation module ************************************* ...
[2014-12-19 07:41:50.313] [I] [core] Starting automation...
[2014-12-19 07:41:50.519] [I] [core] Starting storage...
[2014-12-19 07:41:50.529] [I] [core] ZWay Automation started
Re: Restart error
Was it a fresh install? Seems you don't have Z-Wave binding module activated. You need to configure it with parameters:
port: /dev/ttyAMA0
pierre2302
Re: Restart error
PoltoS wrote:Was it a fresh install? Seems you don't have Z-Wave binding module activated. You need to configure it with parameters:
port: /dev/ttyAMA0
You are right, I had no more module in automation, it looks like the restart of the raspberry deleted them.
The installation dates 1 week
I have already had the same concern on another raspberry with another razberry which was in version 2.0.0-RC21
Thank you very much Poltos
pierre2302
Re: Restart error
I am obliged after every restart to add all the modules because they disappear.
I have this problem since at least the version 2.0.0-RC21 and always with the version 2.0.1 RC6
Re: Restart error
have you tried to do sync after changing modules? Is you automation/storage/configjson-06b2d3b23dce96e1619d2b53d6c947ec.json file empty after reboot?
