Trying to use UZB1 + razberry, no success.
The stick is alive (works fine with Indigo6 on Mac), USB ports are also OK (WiFi adapter works flawlessly)
Linux raspberrypi 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l GNU/Linux
[2014-12-20 22:44:48.012] [D] [zway] Opened device: /dev/ttyAMA0
[2014-12-20 22:44:48.013] [D] [zway] Worker thread successfully created
[2014-12-20 22:44:48.015] [D] [zway] Worker thread entry point
[2014-12-20 22:44:48.025] [zway] Adding job: Get controller info and supported function classes
[2014-12-20 22:44:48.025] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-20 22:44:48.230] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-20 22:44:48.230] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-20 22:44:48.434] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-20 22:44:48.435] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-20 22:44:48.638] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-20 22:44:48.638] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2014-12-20 22:44:48.639] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2014-12-20 22:44:48.639] [C] [zway] Get Serial API Capabilities returned zero.
[2014-12-20 22:44:48.640] [zway] Removing job: Get controller info and supported function classes
[2014-12-20 22:44:48.650] [D] [zway] Worker thread exit point
[2014-12-20 22:44:48.650] [D] [zway] Worker thread successfully finished
[2014-12-20 22:44:48.670] [core] Notification: critical (z-wave): Can not start Z-Wave binding: Error: Bad data - communication failed
[2014-12-20 22:44:54.888] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
UZB1 issues
Re: UZB1 issues
The search function on this forum with UZB1 would have brought you to
viewtopic.php?f=3422&t=20983&p=53742#p53742
