Aeon Labs 1-button Touch Panel
LoganSix
Post by LoganSix »
In doing a little bit of research as I get started, I found the Aeon Labs 1-Button Touch Panel for Micro Switch.
It looks like it would be a good solution for replacing light switches. No need to know if the rocker switch is up or down, because there isn't one. The prices for the panel runs from $20-25, which doesn’t include the $45 micro switch.
Any thoughts on these?
Is Aeon Labs a good company for z-wave products?
procom
Re: Aeon Labs 1-button Touch Panel
Post by procom »
I have one of these installed on my Vera 3, it acts as a satellite relaying switching commands to a designated device or group. You can use it as a scenario controller too. As for device support with Razberry, I don't know.
invaliduser
Post by invaliduser »
I use the touch panel and the micro switches. The touch panels simply replace the manual switch. The brains (and zwave radio) are in the micro switch. They work just find with razberry
LoganSix
Post by LoganSix »
Thanks for the info.
I was "informed" by Aeon that they are going to make a panel that comes with the switch, so that you don't need two pieces. CES has come and gone, so who knows when they will release it.
