I have just received and installed my Razberry & have included successfully an Aeon Multi Sensor. I am trying to configure any of the applications, but none of the changes I make seem to persist.
As a simple example, if I navigate to the 'Old Expert UI' and then to the 'Map' tab &then edit one of the room names (say 'Bedroom' to 'Bedroom 1'. Then click on 'save' at the bottom of the screen. If I now navigate away from this gui and then come back, the changes I have just made are gone.
This feels like some of the config files are 'read-only'. Please help
All config changes are lost on exit
Re: All config changes are lost on exit
These renames as described by you work fine for me. Which steps did you take to install the RaZberry?
I started with a newly installed raspberry b+ with raspian .Then I installed the razberry board and then installed the software using the command wget -q -O - razberry.z-wave.me/install | sudo bash. I then succesfully included an Aeon multi sensor which persists even after a reboot but none of the config changes do persist.
