Device inclusion on Razberry does not work.
mtx123
Post by mtx123 »
I setup a Raspberry Pi B+ with a Razberry.
And performed the setup instructions according razberry website:
http://razberry.zwave.me/index.php?id=24
When I powerup, I see the LED on the Razberry board light up for about 1 sec, that looks good.
I go to <raspbaddress>:8083 and select expert UI.
There I select network-->control-->device management
and try to include a switch, but it is not getting included.
During inclusion the red LED on the Razberry board is on.
I tried this with a Fibaro switch (push 3 times) and an Aeon Labs switch,
but both without result. Both switches have worked fine in another setup before.
Did I skip a step, or is there anything I can do to debug ?
pofs
Re: Device inclusion on Razberry does not work.
Post by pofs »
You should exclude them first
mtx123
Post by mtx123 »
pofs wrote:You should exclude them first
Thanks, that solved the issue !
However it does not seem a very logical way of working to me...
It's just because someone else included it before. If it would be in factory default, it would be included normally without exclusion needed
