Inlusion doesn't work
manwooloo
Post by manwooloo »
Hi forum,
I have an issue including devices. I try to include two devices.
I use the expert UI throw Network/Control/device management.
Inclusion doesn't work. The routing page displays only my razberry.
here is an extract of the log file :
[2015-01-11 14:48:29.011] [zway] Adding job: Add/re-include node to network
[2015-01-11 14:48:29.014] [D] [zway] SENDING (cb 0x19): ( 01 05 00 4A C1 19 68 )
[2015-01-11 14:48:29.015] [D] [zway] RECEIVED ACK
[2015-01-11 14:48:29.017] [D] [zway] RECEIVED: ( 01 07 00 4A 19 01 00 00 AA )
[2015-01-11 14:48:29.018] [D] [zway] SENT ACK
[2015-01-11 14:48:29.018] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2015-01-11 14:48:29.018] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2015-01-11 14:48:29.018] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2015-01-11 14:48:29.018] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
[2015-01-11 14:48:54.234] [zway] Adding job: Add/re-include node to network
[2015-01-11 14:48:54.234] [D] [zway] SETDATA controller.data.controllerState = 17 (0x00000011)
[2015-01-11 14:48:54.234] [D] [zway] SENDING: ( 01 04 00 4A 05 B4 )
[2015-01-11 14:48:54.236] [D] [zway] RECEIVED ACK
[2015-01-11 14:48:54.236] [zway] Removing job: Add/re-include node to network
[2015-01-11 14:48:54.287] [D] [zway] RECEIVED: ( 01 07 00 4A 19 06 00 00 AD )
[2015-01-11 14:48:54.287] [D] [zway] SENT ACK
[2015-01-11 14:48:54.287] [zway] Job 0x4a (Add/re-include node to network): Cancelling job: Add/re-include node to network
[2015-01-11 14:48:54.287] [zway] Removing job: Add/re-include node to network
[2015-01-11 14:48:54.287] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
Any help will be appreciated.
Thanks a lot
Christian
Re: Inlusion doesn't work
In such cases make sure that you have the device to be included very close to RaZberry (about 1 meter)
