Using "expert" commands, I can set the temperature sensor offset on parameter 73, and it's getting this value fine:
[2015-01-14 09:56:29.705] [D] [zway] RECEIVED: ( 01 10 00 04 00 0D 0A 56 01 70 06 49 02 00 00 69 65 8A )
[2015-01-14 09:56:29.706] [D] [zway] SENT ACK
[2015-01-14 09:56:29.706] [D] [zway] SETDATA devices.13.data.lastReceived = 0 (0x00000000)
[2015-01-14 09:56:29.706] [D] [zway] SETDATA devices.13.instances.0.commandClasses.112.data.73.size = 2 (0x00000002)
[2015-01-14 09:56:29.706] [D] [zway] SETDATA devices.13.instances.0.commandClasses.112.data.73.val = 0 (0x00000000)
[2015-01-14 09:56:29.707] [D] [zway] SETDATA devices.13.instances.0.commandClasses.112.data.73 = Empty
[2015-01-14 09:56:29.707] [I] [zway] Node 13:0 CC Configuration: Parameter 0x49 = 0 (size = 2)
The 64536 value I have no idea where it comes from. I set another parameter a yesterday, and it sent the 64536 to the device (the device had 0), and the device then reported a temperature of -76.1 degrees.Nº 73 - Temperature measurement compensation
[64536]
updated: 13.01.2015 | Default value is: 0 |
(I started a post about it before I discovered that this parameter was completely off...)
edit: 112.data.73 is 0 on the JSON API as well. Just not in the "configuration".
edit 2: configuration stays the same after restarts and upgrade to rc10 as well.
