Everspring FS812 automation issue
gilpel
Post by gilpel »
I've just include a new device, FS812 smoke detector. Into the automation module, I only can see the battery widget while other class should be available for automation.
Any idea ?
Mirar
Re: Everspring FS812 automation issue
Post by Mirar »
They are probably Alarms, right? I heard they should work better in 2.0.1, which is still "rc", but you can force the upgrade to that version to experiment. I don't do the automation myself (I use the JSON API), so I can't tell. They still don't show up in the Expert UI. (I have Fibaro ones.)
wget -q -O - razberry.z-wave.me/install/v2.0.1-rc10 | sudo bash
gilpel
Post by gilpel »
Unfortunatly, it's worse ! The battery widget has disappeared without any alarm widget.
thanks for your help.
Gilles
Alarm is not yet in HA UI. We are working on it, but this functionality is very poorly standardized in Z-Wave.
AlarmSensor is implemented now.
