I've written a module that executes a script when SensorBinary level of a sensor is on. The sensor used is a BeNext panic watch. When someone push the panic watch, the following is sent:
[2015-03-26 10:47:28.714] [D] [zway] RECEIVED: ( 01 09 00 04 00 06 03 20 01 FF 29 )
[2015-03-26 10:47:28.716] [D] [zway] SENT ACK
[2015-03-26 10:47:28.717] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2015-03-26 10:47:28.718] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 6 (0x00000006)
[2015-03-26 10:47:28.719] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-03-26 10:47:28.721] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2015-03-26 10:47:28.722] [D] [zway] SETDATA devices.6.instances.0.commandClasses.48.data.1.level = True
[2015-03-26 10:47:28.723] [D] [zway] SETDATA devices.6.instances.0.commandClasses.48.data.1 = Empty
To solve this I thought two solutions:
1. Set sensorBinaryLevel to off. I tried with vDev.set but the change is not persistent, it's just for the virtual device so when I restart the server, the level is again on
2. Access ZWaveAPI and check the updateTime (not the one available in vDev because in restart, it's set whith the time when restarted). I've tried to access ZWaveAPI with an http.request but I get a timeout:
var response = http.request({
method: 'GET',
url: encodeURI("http://127.0.0.1:8083/ZWaveAPI/Run/devices[6].instances[0].SensorBinary.data[1].level")
var sensorLevel = ZWaveAPI.Run.devices[6].instances[0].SensorBinary.data[1].level
