I just updated to the newest version (2.0.0 I think), and now the expert UI says
Error handling data from server
POST http://192.168.100.181:8083/ZWaveAPI/Data/0 - 404 Not Found
So my Script which uses the JSON API doesn't work anymore either, because
"http://192.168.100.181:8083/ZWaveAPI/" just returns 404 Not Found
My z-way-server.log:
[2015-04-07 15:00:59.489] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2015-04-07 15:00:59.637] [I] [core] Executing script: // This script transforms old formats to new ...
[2015-04-07 15:00:59.783] [I] [core] Executing script: ;!function(exports, undefined) { ...
[2015-04-07 15:01:00.003] [I] [core] Executing script: // Underscore.js 1.6.0 ...
[2015-04-07 15:01:00.216] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2015-04-07 15:01:00.253] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2015-04-07 15:01:00.508] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2015-04-07 15:01:00.561] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2015-04-07 15:01:00.583] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2015-04-07 15:01:00.828] [I] [core] Executing script: /*** Main Automation webserver module ***************************************** ...
[2015-04-07 15:01:00.845] [I] [core] Executing script: // Make this testable by pulling in underscore from the parent module ...
[2015-04-07 15:01:00.865] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2015-04-07 15:01:00.992] [I] [core] --- Loading ZAutomation classes
[2015-04-07 15:01:01.396] [I] [core] Starting ZWay Automation webserver
[2015-04-07 15:01:01.403] [I] [core] Loading modules...
[2015-04-07 15:01:01.440] [I] [core] Loading module YandexProbki from modules/YandexProbki
[2015-04-07 15:01:01.456] [I] [core] Executing script: /*** YandexProbki Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.492] [I] [core] Loading module LightScene from modules/LightScene
[2015-04-07 15:01:01.497] [I] [core] Executing script: /*** LightScene Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.515] [I] [core] Loading module OpenRemoteHelpers from modules/OpenRemoteHelpers
[2015-04-07 15:01:01.527] [I] [core] Executing script: /* RaZOR ...
[2015-04-07 15:01:01.530] [I] [core] Loading module CustomUserCode from modules/CustomUserCode
[2015-04-07 15:01:01.539] [I] [core] Executing script: /*** CustomUserCode ZAutomation module **************************************** ...
[2015-04-07 15:01:01.548] [I] [core] Loading module Cron from modules/Cron
[2015-04-07 15:01:01.560] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2015-04-07 15:01:01.708] [I] [core] Notification: error (core): Failed to load module SensorsPolling because Cron was not instanciated
[2015-04-07 15:01:01.709] [I] [core] Loading module SecurityMode from modules/SecurityMode
[2015-04-07 15:01:01.728] [I] [core] Executing script: /*** SecurityMode Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.730] [I] [core] Loading module Notification from modules/Notification
[2015-04-07 15:01:01.744] [I] [core] Executing script: /*** Notification Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.746] [I] [core] Loading module TagOnOff from modules/TagOnOff
[2015-04-07 15:01:01.754] [I] [core] Executing script: /*** TagOnOff Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.756] [I] [core] Loading module RGB from modules/RGB
[2015-04-07 15:01:01.766] [I] [core] Executing script: /*** RGB Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.768] [I] [core] Loading module RoundRobinScenes from modules/RoundRobinScenes
[2015-04-07 15:01:01.781] [I] [core] Executing script: /*** RoundRobinScenes Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.793] [I] [core] Loading module AutoOff from modules/AutoOff
[2015-04-07 15:01:01.798] [I] [core] Executing script: /*** AutoOff Z-Way Home Automation module ************************************* ...
[2015-04-07 15:01:01.800] [I] [core] Loading module HomeKitGate from modules/HomeKitGate
[2015-04-07 15:01:01.817] [I] [core] Executing script: /* ...
[2015-04-07 15:01:01.819] [I] [core] Loading module DelayedScene from modules/DelayedScene
[2015-04-07 15:01:01.834] [I] [core] Executing script: /*** DelayedScene Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.838] [I] [core] Loading module SensorsPollingLogging from modules/SensorsPollingLogging
[2015-04-07 15:01:01.845] [I] [core] Executing script: /*** SensorsPollingLogging Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.847] [I] [core] Loading module SensorValueLogging from modules/SensorValueLogging
[2015-04-07 15:01:01.863] [I] [core] Executing script: /*** SensorValueLogging Z-Way Home Automation module ************************************* ...
[2015-04-07 15:01:01.865] [I] [core] Loading module SwitchControlGenerator from modules/SwitchControlGenerator
[2015-04-07 15:01:01.878] [I] [core] Executing script: /*** SwitchControlGenerator Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.881] [I] [core] Loading module LogicalRules from modules/LogicalRules
[2015-04-07 15:01:01.904] [I] [core] Executing script: /*** LogicalRules Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.906] [I] [core] Loading module ScheduledScene from modules/ScheduledScene
[2015-04-07 15:01:01.914] [I] [core] Executing script: /*** ScheduledScene Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.917] [I] [core] Loading module HTTPDevice from modules/HTTPDevice
[2015-04-07 15:01:01.937] [I] [core] Executing script: /*** HTTPDevice Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.940] [I] [core] Loading module AutoLock from modules/AutoLock
[2015-04-07 15:01:01.952] [I] [core] Executing script: /*** AutoLock Z-Way Home Automation module ************************************* ...
[2015-04-07 15:01:01.954] [I] [core] Loading module SmartLight from modules/SmartLight
[2015-04-07 15:01:01.966] [I] [core] Executing script: /*** SmartLight Z-Way Home Automation module ************************************* ...
[2015-04-07 15:01:01.968] [I] [core] Loading module NotificationSMSru from modules/NotificationSMSru
[2015-04-07 15:01:01.984] [I] [core] Executing script: /*** NotificationSMSru Z-Way HA module ******************************************* ...
[2015-04-07 15:01:01.986] [I] [core] Loading module GroupDevices from modules/GroupDevices
[2015-04-07 15:01:02.001] [I] [core] Executing script: /*** GroupDevices Z-Way HA module ******************************************* ...
[2015-04-07 15:01:02.004] [I] [core] Loading module ImportRemoteHA from modules/ImportRemoteHA
[2015-04-07 15:01:02.020] [I] [core] Executing script: /*** ImportRemoteHA Z-Way HA module ******************************************* ...
[2015-04-07 15:01:02.023] [I] [core] Loading module ZWave from modules/ZWave
[2015-04-07 15:01:02.085] [I] [core] Executing script: /*** Z-Wave Binding module ******************************************************** ...
[2015-04-07 15:01:02.100] [I] [core] Loading module CodeDevice from modules/CodeDevice
[2015-04-07 15:01:02.107] [I] [core] Executing script: /*** CodeDevice Z-Way HA module ******************************************* ...
[2015-04-07 15:01:02.110] [I] [core] Loading module Cron from modules/Cron
[2015-04-07 15:01:02.122] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2015-04-07 15:01:02.125] [I] [core] Loading module ThermostatDevice from modules/ThermostatDevice
[2015-04-07 15:01:02.130] [I] [core] Executing script: /*** ThermostatDevice Z-Way HA module ******************************************* ...
[2015-04-07 15:01:02.143] [I] [core] Loading module Camera from modules/Camera
[2015-04-07 15:01:02.149] [I] [core] Executing script: /*** Camera Z-Way HA module ******************************************* ...
[2015-04-07 15:01:02.192] [I] [core] Loading module OpenWeather from modules/OpenWeather
[2015-04-07 15:01:02.203] [I] [core] Executing script: /*** OpenWeather Z-Way HA module ******************************************* ...
[2015-04-07 15:01:02.213] [I] [core] Loading module BindDevices from modules/BindDevices
[2015-04-07 15:01:02.218] [I] [core] Executing script: /*** BindDevices Z-Way HA module ******************************************* ...
[2015-04-07 15:01:02.220] [I] [core] Loading module Cron from modules/Cron
[2015-04-07 15:01:02.232] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2015-04-07 15:01:02.282] [I] [core] Notification: error (core): Failed to load module BatteryPolling because Cron was not instanciated
[2015-04-07 15:01:02.283] [I] [core] Loading module CustomUserCodeLoader from modules/CustomUserCodeLoader
[2015-04-07 15:01:02.287] [I] [core] Executing script: /*** CustomUserCodeLoader ZAutomation module **************************************** ...
[2015-04-07 15:01:02.289] [I] [core] Loading module DummyDevice from modules/DummyDevice
[2015-04-07 15:01:02.294] [I] [core] Executing script: /*** DummyDevice Z-Way HA module ******************************************* ...
[2015-04-07 15:01:02.296] [I] [core] Starting automation...
[2015-04-07 15:01:02.400] [I] [core] Starting storage...
[2015-04-07 15:01:02.404] [I] [core] ZWay Automation started
