Access-Control-Allow-Origin error, OpenRemote/Z-Wave.me
acehems
Post by acehems »
I have a z-wave network set up using the new Z-Wave expert UI through a raspberry pi. I am creating my own website using an apache2 server to control my devices. The expert UI works fine but when I bring my website up the controls for the devices won't work.
Say my website is set at, "mywebiste.ddns.net", I am using ajax get and post requests to turn devices on and off and to check there status like "mywebsite.ddns.net:8083/OpenRemote/SwitchBinaryStatus/2/0". When viewing the network and console through a browser I get the error:
"XMLHttpRequest cannot load mywebsite.ddns.net:8083/OpenRemote/SwitchBinaryStatus/2/0. No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http:/mywebsite.ddns.net' is therefore not allowed access. The response had HTTP status code 404"
Now I have tried to edit the apache2 config files to add:
Header add Access-Allow-Control-Origin "*"
but that hasn't helped. I have followed http://enable-cors.org/server_apache.html as well as various other forum help and nothing has worked yet.
Anyone have any ideas how to fix this?
Re: Access-Control-Allow-Origin error, OpenRemote/Z-Wave.me
Did you activate the OpenRemoteHelper with the Home Automation UI?. If yes did that work with a local call?
acehems
Post by acehems »
pz1 wrote:Did you activate the OpenRemoteHelper with the Home Automation UI?. If yes did that work with a local call?
I actually completely redid my pi, reloaded raspbian and loaded everything for z-wave onto it as well as ran updates for apacher and it was working fine. I just ran "sudo apt-get update" and now I am getting the same errors. Except now when loading "ipaddr:8083", the first screen will pop up but when trying to go into the expert ui (the old one) it reads "Sorry, the server has not completely started yet".
acehems
Post by acehems »
It seems that the newest version is not compatible with some of the newer versions of raspbian. I reverted to a previous version of z-way-server (1.7.2) and it works perfectly fine.
acehems wrote:It seems that the newest version is not compatible with some of the newer versions of raspbian. I reverted to a previous version of z-way-server (1.7.2) and it works perfectly fine.
The newest official release 2.0.0, or the latest beta release 2.0.1-rc25 ? The latter is afaik compatible with the latest rasbian.
