url api to razberry
cbnidk
url api to razberry
Post by cbnidk »
hi
I can get the status of my switch by this
http://ip_raspberry:8083/ZWaveAPI/Run/devices[3].instances[2].SwitchBinary.data.level.value
I get true or false back in my brower
but I can't find the code to get my temperatur from my SensorBinary
it is a Univeral Binary Sensor FGBS-001 with a DS18B20 sensor
devices[4] and instances[3]
can someone help
Claus
Re: url api to razberry
try:
http://ip_raspberry:8083/ZWaveAPI/Run/devices[3].instances[X].SensorMultilevel.data[1].val.value
where x=3 through 6 for the respective four temperature sensors.
Note the sensors should be connected to the device while you include it. So you may have to re-include.
cbnidk
Post by cbnidk »
pz1 wrote:try:
http://ip_raspberry:8083/ZWaveAPI/Run/devices[4].instances[3].SensorMultilevel.data[1].val.value
Yes this is working! Thank you
with device 4 and instances 3
Claus
