Zipato RGBW
Re: Zipato RGBW
Да, мы поправили много в интерфейсе, стало, вроде, лучше. Спасибо за потверждение.
alv1home
Re: Zipato RGBW
Post by alv1home »
Чего я добился.
С одной лампой, log-level 4, с таким кодом
// --- Class definition, inheritance and setup
function WhiteColor (id, controller) {
	WhiteColor.super_.call(this, id, controller);
inherits(WhiteColor, AutomationModule);
_module = WhiteColor;
// --- Module instance initialized
WhiteColor.prototype.init = function (config) {
	WhiteColor.super_.prototype.init.call(this, config);
	var self = this;
	if (self.config.step < 0.01) self.config.step = 0.01;
	if (self.config.step > 1.00) self.config.step = 1.00;
	this.timer = null;
	this.iHue = 0.0;
    var defaultsWhite = {
        metrics: {
            title: 'RGBW device #' + this.id + ' (White)'
    var overlayWhite = {
            deviceType: "switchMultilevel",
            metrics: { level:0,icon:"multilevel" }
    var defaultsColor = {
        metrics: {
            title: 'RGBW device #' + this.id + ' (Color)'
    var overlayColor = {
	this.vDevWhite = self.controller.devices.create({
		deviceId: "GroupRGBW_" + this.id + "_White",
        defaults: defaultsWhite,
        overlay: overlayWhite,
		handler:  function (command,args) {
			var that = self;
			console.debug(" *** WhiteColor *** handler for White (\'command\':"+command+", \'args\':"+args+")");
			var valueWhiteOld = that.vDevWhite.get("metrics:level"),
				valueWhiteNew = 0,
				valueColorOld = that.vDevColor.get("metrics:level"),
				valueColorNew = valueColorOld;
			if ("on" === command) valueWhiteNew = 99;
			if ("off" === command) valueWhiteNew = 0;
			if ("exact" === command) {
				valueWhiteNew = parseInt(args.level,10);
				if (valueWhiteNew < 0) valueWhiteNew = 0;
				if (valueWhiteNew > 99) valueWhiteNew = 99;
			that.HandlerWhiteColor(that,valueWhiteOld,valueWhiteNew,valueColorOld,valueColorNew);
			that.vDevWhite.set("metrics:level",valueWhiteNew);
		moduleId: this.id
	}); // this.vDevWhite = self.controller.devices.create
	this.vDevColor = self.controller.devices.create({
		deviceId: "GroupRGBW_" + this.id + "_Color",
        defaults: defaultsColor,
        overlay: overlayColor,
		handler:  function (command, args) {
			var that = self;
			console.debug(" *** WhiteColor *** handler for Color (\'command\':"+command+", \'args\':"+args+")");
				valueWhiteNew = valueWhiteOld,
				valueColorNew = 0;
			if ("on" === command) valueColorNew = 99;
			if ("off" === command) valueColorNew = 0;
				valueColorNew = parseInt(args.level,10);
				if (valueColorNew < 0) valueColorNew = 0;
				if (valueColorNew > 99) valueColorNew = 99;
			that.vDevColor.set("metrics:level",valueColorNew);
		moduleId: this.id
	}); // this.vDevColor = self.controller.devices.create
	self.HandlerWhiteColor(self,0,self.vDevWhite.get("metrics:level"),0,self.vDevColor.get("metrics:level"));
WhiteColor.prototype.stop = function () {
	var self = this;
	self.HandlerWhiteColor(self,self.vDevWhite.get("metrics:level"),0,self.vDevColor.get("metrics:level"),0);
	if (self.vDevColor) {
		self.controller.devices.remove(self.vDevColor.id);
		self.vDevColor = null;
	if (self.vDevWhite) {
		self.controller.devices.remove(self.vDevWhite.id);
		self.vDevWhite = null;
	WhiteColor.super_.prototype.stop.call(this);
// --- Module methods
WhiteColor.prototype.HandlerWhiteColor = function(instance,valueWhiteOld,valueWhiteNew,valueColorOld,valueColorNew) {
	var self = instance;
	console.debug(" *** WhiteColor *** HandlerWhiteColor (\'valueWhite\':"+valueWhiteOld+">"+valueWhiteNew+", \'valueColor\':"+valueColorOld+">"+valueColorNew+")");
	var isChangeWhite = valueWhiteOld!=valueWhiteNew,
		isChangeColor = valueColorOld!=valueColorNew;
	console.debug(" *** WhiteColor *** HandlerWhiteColor (\'isChangeWhite\':"+isChangeWhite+", \'isChangeColor\':"+isChangeColor+")");
	if (!isChangeWhite && !isChangeColor) return;
	if ((valueWhiteNew > 0) || (valueColorNew === 0)) {
		self.TimerStop(self);
	self.config.devices.forEach(function(dev) {
		if (dev.active) {
          	var dMaster = self.controller.devices.get(dev.dMaster);
           	var dWhite = self.controller.devices.get(dev.dWhite);
           	var dColor = self.controller.devices.get(dev.dColor);
			if ((valueWhiteOld === 0) && (valueWhiteNew > 0)) {
				dColor.performCommand("exact", {red:0,green:0,blue:0} );
				dWhite.performCommand("exact", {level:255} );
			if (valueWhiteNew === 0) {
				dWhite.performCommand("exact", {level:0} );
				dColor.performCommand("exact", (valueColorNew > 0?self.HSBtoRGB(self.iHue,1.0,1.0):{red:0,green:0,blue:0}) );
			dMaster.performCommand("exact", {level: (valueWhiteNew > 0?valueWhiteNew:valueColorNew) } );
		} // if (dev.active)
	}); // self.config.devices.forEach
	if ((valueWhiteNew === 0) && (valueColorNew > 0)) {
		self.TimerStart(self);
WhiteColor.prototype.TimerStart = function(instance) {
	console.debug(" *** WhiteColor *** TimerStart");
	if (self.timer == null) {
		console.debug(" *** WhiteColor *** setInterval");
		self.timer = setInterval(function() {
				self.TimerNextStep(self);
		self.config.frequency);
WhiteColor.prototype.TimerStop = function(instance) {
	console.debug(" *** WhiteColor *** TimerStop");
	if (self.timer != null) {
		console.debug(" *** WhiteColor *** clearInterval");
		clearInterval(self.timer);
		self.timer = null;
WhiteColor.prototype.TimerNextStep = function(instance) {
    var self = instance,
        moduleName = "WhiteColor",
        langFile = self.controller.loadModuleLang(moduleName),
		vDev = null,
		rgbcolor = self.HSBtoRGB(self.iHue,1.0,1.0);
	console.debug(" *** WhiteColor *** MyTime \'" + (new Date()).getTime() + "\':");
		if (dev.active) {
           	vDevColor = self.controller.devices.get(dev.dColor);
			if (vDevColor) {
				vDevColor.performCommand("exact", rgbcolor);
	self.iHue += self.config.step;
	if (self.iHue > 1.0) self.iHue = 0.0;
WhiteColor.prototype.HSBtoRGB = function(h, s, b) {
                        h *= 360;
                        var R, G, B, X, C;
                        h = (h % 360) / 60;
                        C = b * s;
                        X = C * (1 - Math.abs(h % 2 - 1));
                        R = G = B = b - C;
                        h = ~~h;
                        R += [C, X, 0, 0, X, C][h];
                        G += [X, C, C, X, 0, 0][h];
                        B += [0, 0, X, C, C, X][h];
                        return {
                            red: Math.round(R * 255),
                            green: Math.round(G * 255),
                            blue: Math.round(B * 255)
и частотой 1000 нагрузка увеличивается на 20-30% (htop). Куда копать дальше - не знаю.
И, кстати: когда вызываю vDevWhite.set("metrics:level", что-то больше 0); в web-интерфейсе level отображается правильно, но при этом выкл. Перегружаешь страницу и становится вкл.
alv1home
Re: Zipato RGBW
Post by alv1home »
УЖАС!
Подключил вторую лампу, нагрузка выросла до 90%. Грузит строчка
Вопрос: можно эту команду заменить на что-то менее энергоемкое?
Re: Zipato RGBW
А вы пробовали отладчик JS подключить? Также поставьте много console.log по коду чтоб понять, какие куски часто работают. Если загрузка большая, значит какой-то лишний код выполняется.
Учли, что у setInterval второй параметр в 0.001 сек, а не 1 сек?
alv1home
Re: Zipato RGBW
Post by alv1home »
Нашел, быть может.
В performCommand есть вызов this.controller.loadMainLang(). У меня lang'ов не было, как и папки (ну не нужны мне они). На этом затыкалось. Пару дней погоняю, проверю.
Про setInterval - учел.
alv1home
Re: Zipato RGBW
Post by alv1home »
Предложение (или просьба)
функцию
    performCommand: function () {
        var langFile = this.controller.loadMainLang();
        console.log("--- ", this.id, "performCommand processing:", JSON.stringify(arguments));
        if (typeof this.handler === "function") {
            try {
                return this.handler.apply(this, arguments);
            } catch(e) {
                this.controller.addNotification("error", langFile.vd_err_virtual_dev + e.toString(), "module", "VirtualDevice");
                console.log(e.stack);
переписать в таком виде (если возможно)
            try {
            } catch(e) {
Re: Zipato RGBW
вы абсолютно правы. лучше в следующий раз сделать это через pull request на github. Уже поправил и войдёт в ближайший релиз
pofs
Re: Zipato RGBW
Post by pofs »
Не забывайте убивать таймер в stop(), а то перезапуски модуля будут плодить лишние таймеры
alv1home
Re: Zipato RGBW
Post by alv1home »
Я поторопился!
Нагрузка снизилась до 30%-40%. Т.е. при выполнении команды SetMulti... (чего-то там, не помню) скачок с 15% до 40%. Это замечательно по сравнению с тем, что было. Но 2 лампы - это 60%-70%.
ЗЫЖ Таймер "убиваю" (как мне кажется: clearInterval и timer=null).
alv1home
Re: Zipato RGBW
Post by alv1home »
Побаловался с модулем Fibaro RGBW.
В настройках модуля настроил плавное изменение цвета за 8 сек (параметр 10). В 10 секундном цикле меняю цвет. Razberry "умирает".
Что выведал.
При любом изменении цвета (не крайних заданных значениях, а при любом промежуточном) модуль отправляет отчет в группу 5. В итоге: отчетов очень большое количество, контроллер (или скорей плата Razberry) захлебывается. Сейчас выкинул контроллер из группы - стало красиво (нагрузка растет до 50% при посылке команды, но это раз в 10 сек).
