Fibaro Motion Sensor FGMS-001 not regonized correctly
lauff
Post by lauff »
My Fibaro Motion Sensor FGMS-001 is not correctly recognized.
The picture is not shown.
No configuration is available.
Any idea?
praes
Re: Fibaro Motion Sensor FGMS-001 not regonized correctly
Post by praes »
Same problem here, I tested with Version 2.1.1 and 2.0.1
The device seems to be unknown and you cannot manually select a device configuration.
The sensors work so far, but no product image and no configuration visible.
praes wrote:Same problem here, I tested with Version 2.1.1 and 2.0.1
Try to update your local device description as done in this post: viewtopic.php?f=3422&t=21884&p=57522&hi ... MLs#p57517
The do appear some errors. You can ignore those.
ZWay v2.1.1 does have a record for FGMS-001 that you can select manually if not automatically selected
praes
Post by praes »
ok maybe i confused a bit, the sensor is available in the device selection list but after selecting the device this setting is not applied and the device is shown again as unknown device, i mean you can select the sensor in the dropdownlist but it changes nothing...
steintore
Post by steintore »
Hi, I'm getting the same error. This happened after upgrading to 2.0.1.
None of my Fibaro Motion sensors are showing any configuration.
They do work, but as said earlier, I cannot change the device description and I cannot change any configuration.
