Z-way-server directory [SOLVED]
Locked
Zway424
Post by Zway424 »
I recently installed Razberry and I noticed that I have 2 directories for z-way that have near identical files on my RPi. The directories are called z-way-server and z-wave-server_2015-09-07-12-20-00. Can I delete either folder or are they both being used? Which directory should I be using?
Thanks!
Re: Z-way-server directory
z-wave-server_2015-09-07-12-20-00 is the complete backup of your installation before you upgraded. I tend to keep one version to double check if something funny happens. That being said, it is save to delete that folder and its contents
Zway424
Post by Zway424 »
Thank you for the response! I think I will keep the copy for reasons you have stated.
Locked
