elements that couldn't be removed
Locked
vvuu
Post by vvuu »
I've tested GroupDevices APP and now I have four times GroupDevice_20 in elements section...
I can't remove it via GUI... is there any chance to remove it from system - without erasing zway to factory default ?
Re: elements that couldn't be removed
Thanks for the info, problem fixed: https://github.com/Z-Wave-Me/home-autom ... c89e51d9a5
vvuu
Post by vvuu »
thanks,
I replace file but it is still visible in elements..
what could I do now with it ?
Ah, forgot to write about it.
Open your UI to see the ID of that device (press on the gear and look the ID field). Then stop Z-Way, open automation/storage/configjson-06b2d3b23dce96e1619d2b53d6c947ec.json and in section "devices" remove objects with that ID you found in the UI. Then start Z-Way and enjoy
vvuu
Post by vvuu »
done
thank You :)
Locked
