CGI error
Duvel
CGI error
Post by Duvel »
I'm getting this error when I try to configure my RaZberry after upgrading to the latest version:
****/cgi-bin/main.cgi
Error 500: Internal Server Error
CGI program sent malformed or too big (>16384 bytes) HTTP headers: []
What is wrong here?
ofuangka
Re: CGI error
Post by ofuangka »
I'm getting this same issue. Did you have any luck? I tried increasing mongoose's max_request_size conf entry, but that seemed to break mongoose.
ofuangka
Re: CGI error
Post by ofuangka »
Is there any way to view the main.cgi source?
Re: CGI error
Please try to update again. We have fixed update script today. May be this is the reason. If not, remote support will help.
ofuangka
Re: CGI error
Post by ofuangka »
Still no luck after updating to v2.1.2-rc17-32-g2af918d.
Are there any logs that might be helpful?
ofuangka
Re: CGI error
Post by ofuangka »
FYI, when I try to run ./main.cgi from the terminal, I get a Segmentation fault. Also, I am running on a Raspberry Pi Model A.
Re: CGI error
oh, model A? what is the OS? Raspbian Weezy/Jessie? This can be caused by bad libraries
ofuangka
Re: CGI error
Post by ofuangka »
I'm running on Jessie.
ofuangka
Re: CGI error
Post by ofuangka »
Which libraries does main.cgi use?
