Problems with Information Module / Information Widgets
Desease
Post by Desease »
Are there any known problems with the Information App / Information Widgets in the actual Z-Way Version.
I've tried to make several Informations Widgets with Text oder Links, but the if I edit existing widgets the changes can't be seen in the Rooms.
Especially if I delete the whole App and generate a new Information App. The Widgets in the new generated Apps got the old texts, titles and pictures from the app and widgets I've deleted before. Even a restart between creating new Apps doesn't change something.
It seems that Z-Way doesn't delete the old informations.
I'm using Z-Way on a Raspi2.
Re: Problems with Information Module / Information Widgets
This is a known issue. We plan to fix it in the next release
Desease
Post by Desease »
Sounds good. Thank you for the information.
