Execute code device every ten minutes
nic_rt
Post by nic_rt »
Dear all,
I've one "code device" I would like to execute every 10 minutes. I planned to use scheduledscene to do it but I didn't manage to obtain this behaviour. :oops:
Any help / advise will be welcome.
Many thanks.
Nick
Raspberry + Razberry + FGS221 x 4 + FGRM 222 + Aeon Labs Micro Motor Controller + FGK 101 + Z-Wave Aeotec Smart Plug-in Switch GEN5 + Minimote + Aeotec KeyFob + Greenwave Smart Power Node x 2
jensmoes
Re: Execute code device every ten minutes
Post by jensmoes »
There should be a field titled: "Interval in seconds between polling requests" in the code device itself where you can specify that (600). I use it for my garage door opener and if works OK there.
Forgot to add: Then you should be able to sneak in the code you want executed in the "Code to get value" field, as long as it still returns a meaningful value at the end.
nic_rt
Post by nic_rt »
Thanks for your answer. However I don't have the field "Interval in seconds between polling requests" in my code device ... :cry:
Nick
michap
Post by michap »
Check the App "Poll sensors and log values periodically"
I think here you can add your code device.
Michael
jensmoes
Post by jensmoes »
nic_rt wrote:Thanks for your answer. However I don't have the field "Interval in seconds between polling requests" in my code device ... :cry:
It should appear once you select the type of device to be anything else but the default toggleButton
nic_rt
Post by nic_rt »
Yes you are right : Many thanks. I missed that ! :D
Working now exactly like I was expecting !
Nick
