Hey guys, I'm very new to this and very excited at what I have learned so far from the Rpi community!
I have installed and setup my Razberry, it works great I can connect to it perfectly. I'm going to be using my Rpi to host the Razberry and also the Easy Driver module which will control my stepper motor.
I'm just curious if this will work ok as both will be on the same Rpi 2.
Will doing the bindings be different because its actually on the same piece of hardware?
Thanks so much for any tips!
Travis
Using Nema Stepper Motor w/ Razberry Module on same Rpi 2
Re: Using Nema Stepper Motor w/ Razberry Module on same Rpi
You may need to adjust the GPIO settings (google it for the RPi2, I believe it gets setup somewhere in the config.txt file) and as long as your power supply provides enough amperage, I recommend 2.5A; then I don't see why it wouldn't work.
