Logical rule doesnt work
Henkhaak
Post by Henkhaak »
I'm not able to get my logical rules to work. I try to switch my lamps on when my multisensor sees movement between 6 and 8 am with a logica rule. I see activity on my multisensor, but the lights stay out. What do I do wrong?
This is what I did:
Logical rule in the 'Smarthome UI'
I've set the rule as 'active'
Nested conditions
Boolean operator: and
Time condition >= 06:00
Time condition <= 08:00
Multisensor = on
Actions:
Dimmer, level 40
Coffeelover
Re: Logical rule doesnt work
Post by Coffeelover »
Hi
I had a similiar Problem, which was caused by wrong time zone setting.
Regards
Henkhaak
Post by Henkhaak »
Hi Coffeelover,
Thanks for your answer! Where do you set the time zone? I have the correct time in the menu bar of the UI.
Regards, Henk
Coffeelover
Hi Henkhaak,
I am using the WD NAS with Z-Wave USB Stick. Therefore I have to update the time zone on my NAS. Make sure it is not just to have the right time, but also the right time zone.
Regards
Use tzconfig
albertov
Post by albertov »
If you have raspbian, use "sudo dpkg-reconfigure tzdata"
