I've upgraded to Jessie.
The Expert UI reports "Error handling data from server" as well as " 404 Not Found. Requested data does not exists".
In the /var/log/z-way-server.log file I've found the following-
[2015-10-19 10:02:38.478] [core] Instantiating module 1 from class ZWave
[2015-10-19 10:02:38.480] [core] --- Starting module Z-Wave Network Access
[2015-10-19 10:02:38.509] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2015-10-19 10:02:38.516] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Invalid config
I did perform the following but no joy;
sudo ln -s /usr/lib/arm-linux-gnueabihf/libarchive.so.13.1.2 /usr/lib/arm-linux-gnueabihf/libarchive.so.12
I've seen problems with time going invalid on the IP:8083/smarthome/#/include page as well.
Has anybody seen this and know of a fix? Is is a problem in core networking?
Re: Error handling data from server
Invalid config means there's some folders missing under /opt/z-way-server (like translations, zddx or config).
Please check if these folders are present.
