Hi
in z-way server there is a app module for chowing the history of the sensors for the last 24hours in a chart.
Is it possible to make longer history for sensor logging, or is there another way/module to realize this?
vga
Razberry: Howto log Sensor values?
Re: Razberry: Howto log Sensor values?
Use Sensor Value Logging App and then do whatever you want with the log
Sure, sorry for that post. For any reason i haven´t seen this module all the time
Of course this is exactly what i´m looking for.
i´ve configured the sensor logging module for jsonfile, but where can i find the output jsonfile?
../automation/storage/ does´t contain the logging file and i can´t find it.
in z-way-log file i see this:
[2015-11-18 19:39:36.091] [I] [core] --- Starting module Sensorwert Protokollierung
[2015-11-18 19:39:50.892] [D] [zway] Job 0x13: deleted from queue
[2015-11-18 19:40:00.508] [I] [core] --- histories polled
[2015-11-18 19:41:42.304] [D] [zway] RECEIVED: ( 01 0D 00 04 00 06 07 56 01 30 03 FF D1 CB 76 )
[2015-11-18 19:41:42.306] [D] [zway] SENT ACK
[2015-11-18 19:41:42.308] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2015-11-18 19:41:42.309] [D] [zway] SETDATA devices.6.instances.0.commandClasses.48.data.1.level = True
[2015-11-18 19:41:42.310] [D] [zway] SETDATA devices.6.instances.0.commandClasses.48.data.1 = Empty
[2015-11-18 19:41:42.318] [D] [zway] RECEIVED: ( 01 09 00 04 00 06 03 60 0D 01 9B )
[2015-11-18 19:41:42.319] [D] [zway] SENT ACK
[2015-11-18 19:41:42.321] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2015-11-18 19:41:42.322] [E] [zway] Packet CC::MULTI_CHANNEL_CMD_ENCAP_V2 is too short: required at least 5 bytes, got 3
[2015-11-18 19:41:42.323] [E] [zway] Error returned from _zway_cc_call_handler(zway, command, controller->id, 0, data[4], &data[5]): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2015-11-18 19:42:13.353] [D] [zway] RECEIVED: ( 01 0D 00 04 00 06 07 56 01 30 03 00 CF 3B 67 )
Fibaro device, huh?
Looks like a well-known problem with theirs invalid multichannel packets.
Correct, a fibaro multisensor is included.
Is there any workaround or an upcoming update to get this Sensor working?
Does this app still exist?
Found it but it says only for online usage.
Why is it so difficult to actually log sensor values. I don't want a online service. I just want to make a excel file of electricity usage vs temperature. Over a long time period like months.
Please can somebody help me to make me instructions so we could make it a sticky on this forum as most newbies like me want something as basic as this.
